GLC Class (X254) Produced 2023+
2024 GLC 300 Check Engine Light on
Old Dec 2, 2024 | 11:25 PM
GLC24's Avatar
GLC 300 2024
2024 GLC300, about a year old. Check engine light was on today when driving home. Seattle weather today is 32F ~ 41F. Mileage 7332 miles. After arriving home, connected it with OBD2 scanner and found out the fault code: P0A7F, hybrid battery pack deterioration. Does anyone has any suggestions?
Thanks!
Old Dec 3, 2024 | 07:49 AM
W205C43PFL's Avatar
Thanks!
Hybrid battery deterioration?! That is a first.
Old Dec 4, 2024 | 07:21 PM
ralawren's Avatar
2025 C300W4 AMG, 2023 GLC300 / previous 17 GLC300, 15 BMW 228i, 13 C300, 12 C350 Coupe
We have a 2023 GLC300 4-Matic and have had similar issues for over a year. My wife had the dreaded CHECK ENGINE LIGHT this morning. It eventually went away. The consensus is because we primarily use it for local trips (7,500 miles a year or less) the 48v auxiliary battery is not charging properly. We had it in for service 8 times in the last 14 months. They mostly replaced / upgraded software but there was a recall for the Fusebox. I have been looking at 2024/2025 C300s to replace my W205 and noticed they are having similar issues with the 48V Hybrid technology.
Old Dec 5, 2024 | 12:17 AM
GLC24's Avatar
GLC 300 2024
That sounds like a traumatic experience, and I hope I don't have to repeat yours. Anyway, my story is that the car has been running fine for the last two days despite the CEL being on. Just took the car to the dealer this afternoon and asked the service guy about the alarm code. The person said they haven't seen many 2024 GLC CEL turned on, although I highly doubt that's true. Hopefully they'll call me tomorrow and tell me what they found.
Old Dec 5, 2024 | 08:27 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
similar issues here with a 2023GLC. Have any of you considered the Lemon law ?
Old Dec 5, 2024 | 11:12 AM
ralawren's Avatar
No, I have been using a trickle charger but it only charges the 12v battery. It doesn’t charge the auxiliary battery. I am curious to learn what MB is doing in the 2025nmodels to address this issue.
Old Dec 7, 2024 | 12:28 AM
GLC24's Avatar
GLC 300 2024
A quick update. The dealer hooked up their tester and found the same code. Apparently MB has an internal document called LI54.10-P-077250 that recommends a software update of the A66 with the latest software A 000 903 51 75 for this issue. After the A66 48V battery software update, they did a battery resistance test, and verified that the resistance level is less than 125%, as specified in the document. Well, hopefully the software update will fix these glitches. Let's wait and see.
Old Dec 7, 2024 | 07:10 AM
W205C43PFL's Avatar
https://mbworld.org/forums/glc-class...ml#post8910139
