GLC Class (X254) Produced 2023+
GLC X254 Battery live
Old Oct 2, 2025 | 12:27 PM
stepic7's Avatar
mercedes GLC 220d
I recently got a GLC220d with plenty of amenities
Satisfied, let's say yes
I prefer to guess that problems arise from knowing each other
Let's focus on the issue now:
When starting the car after about 10 days, I got an alert on battery critical charge
Surprised since my previous cars could stay many weeks without caring for the battery level
Indeed, Mercedes used to have a "rest" option for when the car is not used for a while, as the manual for the X254 series accounts
Now for the Mild hybrid as well as on the Plug-in Hybrid the rest option disappeared resulting in a fast battery depletion
I wonder if any other user has undergone the same issue and possible solutions but for recharging the battery
Old Oct 3, 2025 | 12:33 AM
Bwds7's Avatar
I haven't had this issue; however, the longest I've left my GLC 350e undriven was for a week. A trickle charger should solve your issue. There are also battery jump starters that are primarily used for boats that you could look in to.
Old Oct 3, 2025 | 07:57 AM
Gitzer's Avatar
2023 GLC 300, 2021 VW ID4
Many here and on other MB forums have experienced the same battery problem including myself. My “ fix” came after I had three software updates (TSBs) and a battery replacement, all under warranty. Make sure your car has the most up to date software.
Old Oct 3, 2025 | 02:49 PM
404CPE's Avatar
We left our car for 3 weeks (2025 GLC350e) and no problems whatsoever. Kept the plug-in battery low (~30%) as advised in the owner's manual.
Old Oct 5, 2025 | 12:30 PM
DESAL's Avatar
GLC SUV 350e4 Verde Silver Metallic
I leased a GLC 350e last Saturday which was manufactured in March. My23 GLC SUV 12v battery for the last 3 months had low voltage at least once a week. Looking at the Me app, it showed that it had about 1/2 charge even after 30min + drive. Solution replaced battery after a trip to dealer. App showed charge at 100%. Time will tell about the 350e but expect to replace battery at some point. MB engineering really messed up. The other 2 complaints 1- locating of charging pad. 2- in the 350e the top "c:" port next the charge pad. Should have been side by side or lower.
Old Oct 6, 2025 | 04:39 AM
stepic7's Avatar
mercedes GLC 220d
it is not the high voltage battery used for propulsion that suffers, but the 12V battery used for supervision of all the functions
Old Oct 6, 2025 | 04:44 AM
stepic7's Avatar
mercedes GLC 220d
other forums
Hello Gitzer
which are the other MB forums you would suggest?
thanks
Old Oct 6, 2025 | 07:58 AM
Gitzer's Avatar
Another forum is glcforums.com >What’s New. What I like about MBWorld is that it is can be specific to your model GLC as in X254 and that it is monitored well.
Old Oct 6, 2025 | 08:42 AM
Gitzer's Avatar
Hey stepic7 - what year is your car, the GLC220d is not sold in the US (no new diesel cars), the “rest” you reference is actually called “standby”.
Old Oct 6, 2025 | 05:22 PM
404CPE's Avatar
I understand that in M-Bs with a propulsion battery (PHEV, BEV) the 12V battery can be topped up automatically by the high voltage one if required.
Old Oct 6, 2025 | 07:36 PM
Gitzer's Avatar
I believe that is how it works on my VW ID4, so it most likely works that way on Mercedes.
Old Oct 10, 2025 | 12:45 PM
stepic7's Avatar
mercedes GLC 220d
Does anyone know if there is a spare battery on non-Mild Hybrid GLCs to power the electric motor?
Which, by the way is a 16Hp, 12KW, and can't believe it can be powered by the 12V battery
Old Oct 11, 2025 | 01:07 PM
404CPE's Avatar
Likely is - it would be a lot higher than 12V.
