Sport Exhaust adjustment
Old Apr 30, 2019 | 11:09 PM
ChiCubs's Avatar
GLC43 SUV
The sport exhaust only automatically comes on in Sport+. Is there a way to get it to come on in other modes automatically?
Old May 1, 2019 | 11:52 AM
lanoipat's Avatar
2010 Audi S4, 2019 GLC 43,07 BMW Z4 M coupe
Yes ,you can buy a module called ASR .
You can keep the valve open 100% all the time . It's plug and play ,easy to install .
Old May 1, 2019 | 02:17 PM
Toughen's Avatar
C63s
Where to buy? Thanks.
Old May 1, 2019 | 04:11 PM
flhxtsy's Avatar
Car
Just push a button?
Old May 1, 2019 | 04:32 PM
lanoipat's Avatar
You can visit the website
asr-component.de
Or contact Michael if your car is not listed
asr-component
Michael Remerscheid, B. Eng.
Im Hof ​​24
51503 Rösrath
Germany
E-Mail: info@asr-component.de
Old May 1, 2019 | 10:12 PM
ChiCubs's Avatar
GLC43 SUV
No wire cutting?
I have warranty so I don’t want to cut wires. Will this make it obvious if I ever had an exhaust problem to MB?
Old May 1, 2019 | 11:29 PM
lanoipat's Avatar
No wire to cut !
Old May 2, 2019 | 06:14 AM
KevNev's Avatar
GLC63 AMG
Originally Posted by flhxtsy
Just push a button?
The exhaust sounds different in Sport vs Sport+ even if the exhaust button is pushed in Sport mode. Does the exhaust valve actually change between Sport and Sport+ or is the additional sound just a function of the engine being in a different mode?
Old May 2, 2019 | 12:47 PM
Toughen's Avatar
C63s
I think they open valve #3...
Old May 7, 2019 | 02:19 PM
Justin Bond's Avatar
GLC63S
Does having the exhaust switched on the consile not leave the valves open full time regardless of the mode you are in?
Old May 7, 2019 | 04:23 PM
flhxtsy's Avatar
Car
It's a combination of the open valves and the mode programming/shift points, that changes the sound.
Old May 8, 2019 | 11:15 AM
lanoipat's Avatar
The console switch open the valves regardless of the mode you are in but not 100% . Apparently even in sport+ above 4000 rpm t's not open 100% (probably close to it but not all)
The module open 100% when switch in ON .
The simplest way to explain is that you have 3 possible option
Close , Open , Open +
The sound don't change much above 4000 RPM in sport+ mode but def. louder in all mode and lower RPM , deeper tone .
You won't get more bang or fart , at least I didn't !
I like it !
Old May 8, 2019 | 02:21 PM
Nick in NYC's Avatar
GLC AMG63 - 2018
Don't you have the exhaust button on your center console? I can turn it on in any mode but Sport+ is the only mode that it comes on automatically and where it sounds best. You get a better exhaust note in comfort with the exhaust open but not like you get with the way the engine runs in sport+.
Am I missing something?
Old May 8, 2019 | 02:33 PM
ChiCubs's Avatar
GLC43 SUV
ASR
This allows you to not have to hit the button every time you switch between modes and will give best sound in all modes not just sport+
Old May 8, 2019 | 02:35 PM
ChiCubs's Avatar
GLC43 SUV
Read this for explanation
I like it !
What he said
Old May 8, 2019 | 03:05 PM
lanoipat's Avatar
We are talking about the ASR module (add on)
Old Jun 18, 2019 | 10:26 PM
CPD SLK's Avatar
2009 C63 AMG
I'm reviving this because ASR's site is confusing lol...
https://asr-component.de/startseite/...1_mit_schieber
Which one do we order for the GLC63??
Old Jun 18, 2019 | 11:20 PM
lanoipat's Avatar
Yes it's confusing
Just contact Michael @
asr-component
Im Hof ​​24
51503 Rösrath
Germany
Old Jan 30, 2023 | 10:50 AM
adriks1's Avatar
Mercedes GLC AMG 43
Sport Exhaust vs Performance Exhaust
Hi guys,
I know this is an old thread and I’m new to the forum but wanted to see if any of you guys have the answer / experience with this.
Basically I bought a GLC AMG 43 from 2017 which has the Sport Exhaust (not the performance exhaust / stock button).
Obviously the car sounds amazing in Sport + but was wondering if there is a way to make the sound better in Comfort mode…
I have emailed the guys at ASR and they replied that because the Sport Exhaust has no flaps then the module can’t do anything… but I’m confused with some other stuff I’m reading online.
Any help with this would be much appreciated!
thanksss 🙏🏼
Old Jan 30, 2023 | 11:10 AM
lanoipat's Avatar
If you don't have exhaust button , you don't have the OEM AMG performance exhaust . I think the first GLC 43 with performance exhaust came in MY 2019 .
You ppbly have an aftermarket exhaust and ASR system only works on the OEM perf. exhaust .
Does your exhaust have valves ?
Do you have pictures?
Old Jan 30, 2023 | 02:07 PM
adriks1's Avatar
Mercedes GLC AMG 43
Hi Ianoipat,
thanks a lot for your quick answer.
Correct, I don't have the Performance one as I don't have the button. But being an AMG 43 I believe it comes with the normal OEM Sport Exhaust. What I don't know if the normal exhaust has valves / flaps to be honest. I don't think so... which is the problem for the module.
Having no valves... what I don't know is how the cold start changes so much from Comfort to Sport Plus in terms of noise... it must be a computer controlled element correct?
See attached some pics and video.
Cheers
File Type: mov
File Type: mov
Old Jan 30, 2023 | 04:03 PM
lanoipat's Avatar
Originally Posted by adriks1
Hi Ianoipat,
Cheers
you may want to check this old post and threat #7 might be the answer . Good luck
https://mbworld.org/forums/glc63s-gl...e-exhaust.html
Old Jan 30, 2023 | 08:26 PM
pussgalore's Avatar
na
I recommend the ASR module. Before purchasing I couldn't really discern any difference on YouTube videos, but it does change the sound quite a lot in my 63S even in Comfort.
Old Jan 31, 2023 | 05:52 AM
adriks1's Avatar
Mercedes GLC AMG 43
Thanks lanoipat!
@Pussgalore I guess that's because your 63S has the exhaust with flaps. I have emailed the guys at ASR components and because my exhaust is the stock sport exhaust from 2017 there aren't any flaps to control on the end... it's controlled by ECU and engine changes behaviour on Sport + that's why it sounds a lot louder than in Comfort mode... apparently there is no way to change this without remapping which I don't want to do... shame!
Old Feb 3, 2023 | 05:13 PM
ChiCubs's Avatar
GLC43 SUV
Hey I had a burble tune done by MBHouse.ca
i live in the US and they do it remotely. I’d say check with them and they can probably do it for you.
