GLC43 lower by setting?
toggle the switch to sport plus with the key on
and the vehicle will lower.
You can feel it lower !!!
You also have a switch on the right side of console very rear switch which has a car with a arrow on it you can use this switch to raise and lower your vehicle.
However you can raise your vehicle and it will stay there until you go 35 mph then it will automatically lower to normal.
1. On the center console right below where you put a CD in, push the button in between the hazzard lights button and the "TEL" button that looks like a car.
2. Push the command knob..... then turn the knob to the "Dynamic Select" selection that looks like the back of the truck.
3. Push the command knob under the "Vehicle Data" Button. Done.
Selecting "Engine Data" will bring up the gauges display.
I can post pictures if someone doesn't understand those 3 steps. Remember, those little buttons beside the CD/DVD panel are basically shortcut buttons.
