2020 GLC63 - My first problem?
Anyone else had this behavior with snow tires?
The only thing I can think is that the car came with 295/35 R21's; even though the dealer ordering guide from July has the stock 21 size as 295/40 R21s. Could this be causing the problem?
Also tire sizes vary from one brand to another, just because the numbers match, actual measurement might not be the same.
https://www.caranddriver.com/feature...tire-sidewall/
As for the dealer keeping your wheel lock, it's possible. It shouldn't happened since the tech should have all lock combos (usually a few) in his tool box, but sometimes they lose them and have to use yours. Just let the dealer know and if they can find it, they should get you a new one.
For 21"
Front: 265/40R21 and Rear: 295/35R21
Click on the specs and the "overall diam" is 29.3" and 29.1"
https://www.tirerack.com/tires/tires...V&autoModClar=
For 20"
Front: 265/45R20 and Rear: 295/40R20
"overall diam" is 29.4" and 29.3"
As long as the Overall Diameter ratio between the fronts and back similar (the fronts 0.1" - 0.2" taller than the back) you should be fine.
Anyone want two 295/40R21 Pirelli Winter Scorpions on the cheap? They only have a couple hundred miles on them....
