Does anyone know of an aftermarket spare tire kit being produced yet for the 2020 GLC 63 coupes? I realize that the car comes equipped with run flats, but that does no good if you happen to cut a sidewall. Thinking there will be someone who designs a skinny spare that fits flush under the cargo area AND that will still clear the brake calipers.
Quote:
The 2020's have runflats? Yuck...Originally Posted by southof30a
My 2019 had standard Summer performance tires.
Strange I’ve got a 2020 GlcG3 and it has P zero conventional tire. No spare or jack. Just a air compressor and a can of goop.
The 2020 GLC 63 doesn't have run flats. It has standard summer tires with an air compressor kit and sealant.
Quote:
I believe they come standard with MOE tires don't they? It's been a while since I had the original tires but I was thinking they were P Zero MOEs on mine.Originally Posted by 4ringsnbr
https://www.mercedes-benz-performanc...mmended-tires/
Not sure about others, but my 2020 w/21s came with MO1 PZero (not MOE).Originally Posted by ParadigmDawg
I believe they come standard with MOE tires don't they? It's been a while since I had the original tires but I was thinking they were P Zero MOEs on mine.https://www.mercedes-benz-performanc...mmended-tires/
MO1 has some AMG tweaks to compound from what I've read, but definitely not MOE capable
No-- my 2020 GLC63 has Continental SportContact 6 MO1 20" tires. I've not seen any GLC wearing MOE (which are extended, not truly run flat) tires.
I knew there was a M in there somewhere. I do believe you are correct and I was wrong.Originally Posted by BlkSVT
Not sure about others, but my 2020 w/21s came with MO1 PZero (not MOE).MO1 has some AMG tweaks to compound from what I've read, but definitely not MOE capable
ExploreCurrently Active Users (1)
