2020 GLC 43 Audio not working
Thanks.
Tom
I have a 2020 GLS 450 and I have the exact same problem. I am sorry about your frustration, but I am so glad you posted here because I thought I was going a little crazy. It does seem to work if it has been off, but, you are right, with such a new (and expensive) car, this is ridiculous. Does anyone know if there is a long-term fix? Or if there is something you can do while you are driving so you don't have to stop and wait for it to reset?
Since you posted so long ago, I was hoping you might have figured it out
Thanks.
Tom
I experienced this on my 2020 GLC43. No audio of any kind, no radio, no Apple Carplay, nothing. Went into the sound settings where you set the options (Bass, Mid, Treble), and the up down arrows were there, but there were no numbers. Went into Dealer Mode and looked for the Audio options, completely blank page - it was as if audio just didn't exist on the car.
I created a new user profile, switched to it, and then switched back and then sound started working again.
This has been happening to the car for the last 2-3 weeks and no amount of time of leaving it off has worked (no updates have seemed to go through) - I've left it off overnight to a couple of days while traveling, still no 'auto-fix' as some have discussed above.
I tried factory resetting MBUX - that didn't work off the bat - I did create a new profile (due to the reset, this also didn't work) however what I haven't tried is creating *another* new user and switching between the two of them, to your point @TheRealAlfonso - will give that a shot tonight - but really a really curious problem indeed.
I would love additional feedback if anyone has!
I found the reason mine didn’t work is I didn’t allow enough time for the audio to initialize/ set before I started moving the car. Once the car is in motion, it seems the audio setup stalls and you have no sound. Giving it the extra minute or so it needs to set up after you start the car and before you begin driving, may be the solution. Hope that helps!
