GLC43 Buzzing/Vibration Noise
Old Aug 9, 2020 | 07:21 AM
oni1's Avatar
GLC43 AMG
Exclamation GLC43 Buzzing/Vibration Noise
Any idea what this is - does it sound normal to you?
Old Aug 9, 2020 | 08:34 AM
Sifor's Avatar
2020 GLC 43
Does not sound normal. Not sure what it is unfortunately, maybe someone else here might know. In any case, I'd be getting someone to look at it..
Old Aug 9, 2020 | 08:38 AM
places's Avatar
No more MB:(
Op needs to chill out, started another thread on the C sub forum same topic.
If it's so concerning take it to the dealer.
Old Aug 9, 2020 | 08:47 AM
oni1's Avatar
GLC43 AMG
Dealer is saying it's normal...
Old Aug 9, 2020 | 09:12 AM
places's Avatar
No more MB:(
Well then it's either normal or try another dealer. It's not a big deal. Chill out.
Old Aug 13, 2020 | 07:33 PM
thisglc's Avatar
glc 43 amg
It does sound funny, but I can't put my finger on it. But perhaps OP could, very carefully. It sounds like something is rubbing or perhaps vibrating. Assuming this is easily reproducible, I would be tempted to touch/hold/squeeze/wiggle one part/hose/cover at a time. Be very mindful of moving pieces and belts. Consider using a thin but stiff stick. I think what I'd look for is changes in "tone" of the sound. By touching a vibrating part with some pressure, you'd affect its resonance frequency and thus affect the sound pitch or quality. I think the odds of successfully debugging are lowered by the "rotational" quality of the sound as my procedure does not work well for pulleys, belts, or shafts. But you never know. My 2 cents.
Old Aug 13, 2020 | 08:07 PM
oni1's Avatar
GLC43 AMG
Thanks for your input. I tried it the other day and i pinpointed the noise to what looks like a solenoid valve in front of the engine. Part # is A0081535428. Taking back to dealer on monday. If replace this, hopefully noise will go away.
Old Aug 18, 2020 | 06:54 PM
JNoel's Avatar
GLC43 AMG + SL55 AMG
Hey...
I own a 2017 GLC43 and I had the exact same vibration/noise....but i had one more symptom that led me to exactly what it was......
with this vibration/noise my radiator overflow tank was spilling out anti-freeze. this issue was this little tank cap which is releasing i addressed it to the dealer and they fixed it. I am not sure what the changed or actually done to fix it, but my guess is the tank cap was replaced.
good luck!
Old Aug 19, 2020 | 04:26 AM
viper43's Avatar
GLC 43
I had the same problem on my 2018 43, the mechanic at MB Northshore said it was a valve that keeps the water to air intercooler system pressurised. Replaced under warranty a month ago. Pretty embarrassing when your 43 farts its way around the carpark
Old Aug 19, 2020 | 05:19 AM
oni1's Avatar
GLC43 AMG
Dealer says they are unable to reproduce the fault after extensive road testing which makes it difficult to pinpoint the faulty component. Foreman has submitted a TIPS case to Mercedes-Benz technical team, and escalated to Germany. They are waiting for the result to come back. FML
Old Aug 31, 2024 | 03:43 PM
p.moreno@khbrig's Avatar
2020 GLC43 AMG
Buzzing Noise 2020 GLC43 AMG
I have the same exact noise coming from that same vacuum solenoid valve. I have attached a video and a picture of the part number of the offending item. I have an appointment with the dealer and will update here with results. Perhaps not so coincidentally; I can smell coolant but can't find a leak. Maybe the cap as mentioned. And maybe if the cap is not holding pressure it cause this val to activate constantly in a failed attempt to maintain proper pressure? Just a guess that may make sense if the noise is "normal" when activated occasionally if the system is properly sealed. I may be way off but I will update wafter my visit to the dealer. Thanks for all of the information.
File Type: mov
