MBHouse (Canada)
https://www.mbhouse.ca/product/intel...ight-control2/
their process is different which I plan to document…
they are using flexihub to push coding for the 3 things I have ordered
1. Adjusting blinker default from 3 to 5 blinks on a tap.
2. Remember last driving mode. It’s got a 4 hour memory so if I’m in S+ and turn the car off to pump gas, it’ll start in S+
3. Eurospec ils+. This is the same upgrade that Vlad sells for those who are familiar with him. Great guy who I may end up getting the lowering item from.
More to come…
More to come…
neither of my Mac’s worked. They’re working on a solution so standby.
I imagine that I was a bit of a guinea pig for them so with that in mind; The problem was with a security block on my Mac. They were able to figure it out and walk me through allowing the connection to work.
All products were installed correctly and are working.
The blinker goes 5 times on a bump now which is nice for lazy lane changes on road trips.
The last driving mode memory is awesome. When I’m in Eco on a long road trip and stop for gas I always forget to put it back in eco. Same with S+ on fun days.
The ILS+ I won’t know until this weekend when I’m out in BFE at night. There’s an option in my menu now that wasn’t previously.
The overall time to complete these was about 2 hours end to end once the security issue was resolved.
I have no complaints and would use them again.
I just sent you a pm. Let me know if you need anything.
I absolutely recommend using MBhouse and am pleased with their ability to remotely install upgrades.
I’m in the process of installing their burble tune. It’s so much more aggressive.
if you are looking to do mods you should check out their site. MBhouse.ca
I am interested too .
Does it work on sport + only ? Do you need to have a tune from them ? Do you have to keep the ODB tool plug to use it ?
It works on all drive modes. The OBD is only to push the code in and then removed after install.
I have a final install coming and will post a video.
definetly worth it!
