Longevity of M276 Engine
Old Mar 8, 2025 | 09:14 PM
jwells222's Avatar
2021 AMG GLC63S Coupe
In addition to my 2023 GLC43 V6 coupe, I also have a 2003 Acura CL-S with a 3.2Litre V6. The Acura has 275,000 miles on it and shows no sign of giving up any time soon. As far as I can tell, it the engine is as robust as it was in 2003. I have no doubt it will make to 350,000 miles if I drove that much. Honda/Acura make engines that are designed to last for many miles. MB makes engines with performance as the primary consideration. My question is, how many miles do you think an M276 V6 engine can go before major repairs are needed assuming maintenance per MB recommendations and moderate driving habits.
Old Mar 8, 2025 | 09:30 PM
W205C43PFL's Avatar
It might not last as long as the Honda/Acura engine (or it actually might last as long or longer) but the M276 is one of the most reliable MB engines for a while. There are common problems in earlier batches such as camshaft adjuster issues though. Do not assume maintenance per MB recommendations, you need to half those intervals or at least more frequent, especially OCI. You also want to do preventative maintenance.
Old Mar 8, 2025 | 09:34 PM
jwells222's Avatar
For sure on the maintenance. I feel comfortable with oil changes every 5,000 miles rather than 10,000 per MB guidelines.
Old Mar 8, 2025 | 09:38 PM
W205C43PFL's Avatar
Transmission fluid should be done every 5 years or 50,000 miles (if I recalled correctly that is the factory interval and that is good enough, you can stick with the schedule for the transmission), spark plugs 5 to 6 years (although I think certain MBs had it at every 3 years, for example my family members' E 450 shows every 3 years for some reason), front and rear differential fluid, transfer case fluid, brake fluid every other service, coils, coolant, eventually need transmission and engine mounts, eventually need shocks, obvious things like brake pads and rotors, tires, alignment, tire balancing, engine air filters, cabin air filter, activated charcoal cabin air filter (beneath the glovebox), polv v belt, check all belts, 12V battery in 6-8 years although more likely the former, auxiliary battery whenever that fails.
Those are off the top of my head I might had missed many things though.
Old Mar 8, 2025 | 09:41 PM
W205C43PFL's Avatar
Forgot to mention: Other obvious things like windshield wipers that are also wear and tear
Forum member @chassis wrote a nice DIY guide with various wear and tear items: https://mbworld.org/forums/gle-class...ispreloading=1
Hopefully forum member chassis can include the things I missed.
Old Mar 8, 2025 | 09:51 PM
jwells222's Avatar
Above and beyond what MB includes on those A and B schedules, this is what I've pieced together with the help of the service department:
Spark plug replacement Every 50 or 5 Years
ATF drain and fill with new filter Every 60 or 6 Years
Front Differential case drain and fill No scheduled interval, but every 60 or 6 Years is
advisable
Rear Differential case drain and fill Every 30 or 3 Years
Transfer case drain and fill Every 50 or 5 Years
Steering fluid drain and fill N/A - Electronic fly by wire steering so no fluid
Engine air filter Every 50 or 5 Years
Replace fuel filter Every 120 or 12 Years
Coolant drain and fill Every 120 or 12 Years
(main circuit and low temperature circuit)
Old Mar 8, 2025 | 09:56 PM
W205C43PFL's Avatar
advisable
I have a 2017 C 43 with the same engine, I am planning to keep it for a very long time. Even if I get a new car (I was considering a CLE 53), I will still keep this one alongside. I am very satisfied with how it doesn't have a complicated drivetrain, mild-hybrid, plug-in hybrid, hybrid. The M276 is an overall great package.
Old Mar 8, 2025 | 09:58 PM
W205C43PFL's Avatar
I want to bring your attention to this mod though, it is experimental but proven to have benefits: https://mbworld.org/forums/c450-c43-...-oil-flow.html
I already did the mod: https://mbworld.org/forums/w212-amg/...ml#post8963720 (you should read the first page's frequently asked questions).
Old Mar 8, 2025 | 09:59 PM
W205C43PFL's Avatar
Here is another experimental mod I also did: https://mbworld.org/forums/mercedes-...s-voltage.html
Old Mar 9, 2025 | 08:34 AM
chassis's Avatar
2017 GLE350 4MATIC
No way of knowing. MB does not make engines as robust as Japanese brands. You are comparing opposite ends of the reliability spectrum. Do not expect Honda reliability or lifespan from an MB engine.
The M276 is the most reliable MB engine in at least 20 years, in both configurations of 3.5NA and 3.0TT.
Staying ahead of all maintenance is required. Early spark plug, engine air filter and oil changes are advised. I change oil on my Cayenne every 5k-6k miles using a cheap store brand oil filter and my Blackstone results are excellent.
Replace ignition coils every 50k miles.
Inspect the engine bay and underbody regularly for signs of leaks.
MB transmissions depend on oil change at the specified interval.
In summary, do the maintenance.
Old Mar 9, 2025 | 03:49 PM
W205C43PFL's Avatar
Forgot to mention various things like wheel bearings, driveshaft hangers, many bushings, mounts, etc. will eventually wear out so keep that in mind.
Old Mar 10, 2025 | 04:33 PM
CA400's Avatar
C400
I have a 2015 C400 at the cusp of 200K miles. I've had the camshaft adjuster issue for the past 2 years (sometimes it makes the noise sometimes it doesn't). The adjusters have been the biggest issues I've had with the car. I've replaced motor mounts (break stance so my fault), transmission mount at the same time as motor mounts, front control arms (I had K-Macs, never worked had to replace, again my fault). The radiator and alternator were replace last year, other then that I've had maintenance items only, I change my oil every 5K miles and use Liqui Moly, with MB filter and add ceramic Liqui Molly protection at oil change.
I feel, if I would have left my car stock, I wouldn't have had so many issues but most likely not been able to avoid the camshaft adjuster issue. At this point, I'm undecided of fixing the adjuster issue or getting rid of the car. I just got the GLC63 (do not want to use as a daily), so to replace the C400 I would get another used vehicle that I do not know the ins and outs of. The C400 is still fast! If I line up against a newer C450/C43, it makes for a very interesting race and I'm only Stage 1. I can only imagine what it would do once everything is freshened up!
Old Mar 10, 2025 | 04:44 PM
W205C43PFL's Avatar
200K miles is a very healthy number, congrats : ) Did you get those high mileage rewards?
Old Mar 10, 2025 | 04:45 PM
W205C43PFL's Avatar
https://www.mbusa.com/content/dam/mb...pplication.pdf
Old Mar 10, 2025 | 04:48 PM
CA400's Avatar
C400
I know I can report to MB and get some sort of emblem for the grill, may look more into that!
Thank you for the link W205C43PFL
Old Mar 10, 2025 | 04:49 PM
W205C43PFL's Avatar
I would recommend just leaving it at home though once you get it, you don't want to put it on the grille, you could loose it or someone might steal it.
Old Mar 10, 2025 | 06:34 PM
W205C43PFL's Avatar
You're welcome : )
