Dashcam options
), that would be nice, but for now, this is my setup:Battery pack and battery pack hard wired cable stored here, I might even get a second one and put it on top.
I use the cargo 12v fuse and add a fuse kit. Then use the fuse box mounting bolt as ground. The wire is routed behind the foam on the left side of the fuse box to the top. The *** cable is coming from there also, and through a small gap between the trim piece into and behind the tailgate weatherstrip.
Long cable bridging across. If you can help me with the tailgate trim removal, that would be nice. I think for the headliner, you just need to pull the weatherstrip out, and you can pull the headliner just enough to fish the *** cable through, but it would be nice if you can walk me through your process also.
For the front, I zip tie the two cables onto the factory harness, so that it will not interfere with the airbag.
and location of the front camera.
I will try to do that tomorrow. Definitely don't like the hanging cable especially when its closed
I used a coat hanger to push the cable behind the trim to this hole and pulled it through.
I removed the trim surrounding the hose for easier access. The trim above the hose on both sides slides upwards. The remaining trim pulls towards you. (Note: the pins that hold the trim each have a felt washer that goes between the pin and the car and can fall off when trying to reinstall). The rubber gasket on the bottom can get in the way. The bottom part of the hose is like a grommet and is press fit into the hole to the roof of the car. It just needs to be pulled out. There’s an arrow on the rubber closest to you where you can slide the trim remover under and pull it out.
Once the hose is free, I compressed the hose like an accordion. I then slid the coat hanger straight through and pulled the cable through.
In the hole in the middle there’s an aligned that is glued to the headliner. This was where I fed the cable down into the ceiling and then it goes straight down the side pillar into the fuse box area. Then just follow the same path as before.
Hopefully this helps. I’m going to have to tidy up my install once the longer cable comes in.
For the front A pillar, how does the trim come off where it’s closest to the dash? Does it just pull towards the middle of the car or pull backwards towards the rear of the car?
I will try that tomorrow since its a bit late now and got to get up early to work
If you are talking about the trims next to the doors, you will have to first remove the one next to the glove box.
Open the glove box and use the removal tool to open up the rear part (toward the back of the car, right next to the glove box opening. Once you get it open, you have to take it out and away from the passenger door (you will see the tab at the back). Once you got that open, the small vertical piece is held by one clip at the top. Unclip it, and pull (carefully) the top toward you and lift it up and away. The bottom of that trim is held together with tabs with the bottom trim (the one where the fuse box are). One that one is removed, you can remove the fuse box trim piece.
Let me know if you need more information.
Thanks to tinman831 for helping me in removing the trims
The clips that holds the trim piece are those below, and with the black rubber washer:
There are a total of 7 clips holding the entire piece in place, 2 of each side, and 3 in center. Once you know the location of those clip, its very easy to pull out.
And final product
I ordered the 5.5m power cable from blackvue directly. I need the extra length since I want to have a battery pack at the rear. The original 4.5m is just a bit too short, and i can't seem to find the 5.5m outside blackvue.
Thanks.
There are also Mini fuse slot available, but I am not sure if those are constant or ACC powered.
Some additional pics that might help. Pop open the cover for the fuse box in the cargo area. It’s easy to access. Take a look and decide which fuse you want to use.
Thanks.
Dear Gregory,
Thank you for your email to Mercedes-Benz USA.
At this time, the dash camera feature is not available within the U.S. market, as well as additional details for future updates. As a valued Mercedes-Benz customer, we welcome your feedback. It helps to keep us current in understanding the needs and preferences of our current and prospective customers. To this end, we have shared your comments with our GLE-Class Product Management Team for their review and future consideration.
We appreciate the opportunity to respond.
Kind Regards,
Mercedes Benz USA
(800) 367-6372"
Customer By CSS Web (Gregory Williams) (11/26/2019 10:19 AM)
My 2020 GLE has a dash cam feature that is not activated. I know it says "not available in all countries, but both BMW & Tesla have this feature in the USA. This would be highly useful. Is there a chance it will be enabled by a software update in the future?
It was announced at IAA September, 2019, and at least at that time only for the Russian market (€426 F+R).
We ended up installing the Thinkware U1000 4k 60hz front, 2k/30hz rear. Happy so far. Planning to move an existing Thinkware F800 Pro to the GLE350...
