GLE 450-Some Random Thoughts & More
Now, if only I could get the AMG wheel, too!
The Service Manager just emailed me to tell me that both are known issues with a fix pending soon. They targeted end of third quarter so only 3 months behind now. If you have the Fob or Assistant problem maybe there will be a fix soon. I should have an update soon.
Regarding profiles, questions:
1) I have multiple profiles. Upon entry, it’ll show the welcome screen with user profiles to select, however it seems to automatically default to main driver after a couple of seconds of showing the Welcome screen and screen disappears. This happens when you start the engine. Is the profile key dependent, so meaning it knows that the key fob is on me and will default to main? I was under the impression you can select the profile upon welcome screen. Cant really select a profile as within seconds the screen will disappear as it’ll default to Main. I’ll have to go activate the other profile via the other way by going back to profile. If I just enter, the welcome screen will be displayed to select profile, which doesn’t go away, until you start the engine which will default to main
2) How do you customize other user profiles via Mercedes Me? One of the profile is already linked as Main User. There is a Guest account and I have another profile but the third profile can not be customized online. Does it have to be linked if so, how since it only appears one profile can be linked to the main profile (eg adding profile picture on other profiles) Does that make sense? I am only able to Customize the Main User profile for some reason. All the other profiles only have the option to link/unlink but I can’t link or anything since it’s greyed out. Do the other users have to be registered as Co user?
Some minor annoyance:
1) keyfob and locking issue which people have reported
2) windshield wipers skipping at low speeds
thanks!!!
thanks!!!
I still get a little skipping at low speed when moisture is light. It’s that condition when it’s stopped raining and the wiper might make a single sweep. Chatter was severe until I used steel wool and degreaser to remove a gluelike residue from my windshield, present at purchase. Then I cleaned the wiper blades with WD40. As I recall new blades are replaced at each 10,000 service (unusual) and maybe a tip that the rubber is different, maybe softer.
I had it engage on me already at least 5 times when nothing was present behind the vehicle.
The worst part is that there isn't any kind of warning, the beep happens after it is already engaged.
Our Audi will auto brake if I back into the garage too fast and sometimes gives off an alarm even at lower speeds.
If this is a recent change....you might disconnect the battery ground for a few minutes to eliminate the possibility of software gremlins. MBUX FU3 is rumored to be near release according to my Service Manager. Each update seems to reduce the number of issues.
I guess I will take her in after the holidays to see fi there are some updates etc. have a long trip coming up in late January
If connected through the USB connector, it always rings through the car speakers.
Was wondering if anyone else is having the same issue?
(I had mentioned this in a separate thread...so apologies for a duplicate post...but the subject of the thread didn't really apply to the actual issue and I can't seem to be able to change the subject line or delete that thread).
2018 (V7.0) N. America
@2016 Here
Satellite View of Earth :NASA Visible Earth
Under Details does show a 2019 version for NE US
Yesterday had a "Online service currently not available" message for a period of time...
Could that message be showing when a download is taking place???
