GLE 450-Some Random Thoughts & More
The number is apparently traffic delays in minutes from construction or accident related slowdowns and detours. The car symbols do not appear in the symbol listing in the manual, but may be elsewhere. Driving along mine popped up with 8 minutes and directed me to detour off the Freeway. I ignored the change knowing that there was construction ahead narrowing to a single lane each direction. As soon as I passed the detour the time jumped to 35 minutes. I soon discovered that a truck wreck had closed the road ahead and I was stuck waiting. Luckily they had opened one lane and my wait was about what the detour would have added but had been an hour earlier.
MULTI CONTOUR SEATS-I thought the seats were firm but comfortable until I took a trip. After a few hours they become very uncomfortable. They bothered my wife’s back late in the ride but were also not good in other ways, just too firm. She can’t describe any specific issue just says they aren’t comfortable. I have adjusted the Lumbar and side bolsters. The massage function doesn’t seem to help. I tried most of the massages, trying a new one each time it shut one off. The function shuts down after a few minutes. Even with the lower seat extender out the front bothers my thighs. All the way in leaves a slight hump making it worse. Looks like a seat cushion for trips will be needed. I got some relief by lowering the seat front so that my feet on the floor keep my thighs off the seat.
DRIVER ASSISTANCE PLUS-I posted some observations in a separate thread about issues. I find it useful and would buy it again if it didn’t require the Multi Contour Seats which it does.
DRIVING MODE-After several different settings I have settled on Comfort around town & Individual Mode for the highway with all I settings at Sport except the Engine at Comfort. I plan to experiment with Economy Mode in the future but so far not much advantage noted.
PERFORMANCE-The engine and transmission are well matched and there is good acceleration for passing. It’s smooth, linear and a little deceptive. One might always want more power but there are trade offs. I test drove the 2018 GLE 43 several times and it felt sluggish in comparison. The EQ Boost May be the difference.
FUEL ECONOMY-The vehicle calculated mileage on mine is extremely accurate. On one leg of my trip driving in Comfort Mode, mostly 80-85 with a 12-15 mph headwind and 382 miles the car said 20.2 and calculated 20.15. Another leg at the same speed and no wind to maybe 5 tailwind at 410 miles; car 24.2 & calculated 24.18. My distance and range to empty added together were over 550 miles on the second leg. On flat ground at 60-70 the car often reads low 30’s and speed and headwinds often drop it below 20.
NOISE-At highway speeds the car picks up a little more road noise than our Audi that has Acoustic windows. I had that package ordered but it somehow disappeared when the order locked.
HIGHWAYS-The GLE is very smooth at high speeds. You can easily find yourself going faster than you realize because it’s so well mannered. It handles well in corners at speeds in excess of the posted limit. I had a spot with no traffic that I ran it up well over 100 but it still felt more like 80.
CLOTHES HANGER-My wife went out to put on the bar to hang her clothes only to find that there are no hooks for the bar-that’s a first. I had some 3/16” rod that I was able to shape into a loop for the bar and a loop to attach to the rear “hand hold” above each door. I might put some shrink wrap on them and call it good. I haven’t seen anything listed as an accessory but surely there is something???
Edit 5/25: Received it today- beautiful tool!
One question. Sometimes (with cruise control on), I notice an image of vehicle pop-up in a circle and then disappear. Does anyone know what this means?
And I found in the DOG where it specifies 3 come as standard.
- Curve function has 3 setting levels. Level 3 is quite pronounced and interesting. Takes a while to get used to, but kinda cool.
- Sport is probably my favorite mode. Roll is well controlled but there is still a good deal of suspension compliance.
- Car lowers while driving in Sport & Sport+ (2 different levels). When car is off you can set it to lower down to the lowest level; does it quickly and looks pretty racy.
- Comfort and Curve modes are pretty plush, even with 21s.
- "Free Driving" where the car hops up and down is kind of fun to use at stoplights!
- Coming to a stop you can get a little bit of front end dive at the end unless you are careful to modulate the brake, which is just good practice.
- Everything has worked fine, but I do worry about the complexity a few years down the road, which is why I got the ELW, I think the Active Ride with active roll control on the upcoming GLE 53 might be the perfect compromise between performance and cost/complexity.
1) To set the Curve function to one of the three levels, you can toggle to "CV" using the Dynamic Select switch on the console, or using MBUX (Home>Settings>Vehicle>DYNAMIC SELECT>CURVE. You should then be able to select it and choose one of the inclination levels.
2) I had problems engaging Free Driving at first as well; the manual is clear if you read it carefully. To use Off Road Assist, first you have to select Off Road mode, which is the bottom one, below CV, scrolling down using the Dynamic Select Switch. Then you should be able to go to vehicle settings, select Off Road Assist, then either Free Driving Assist or Individual Wheel Control.
Probably the same on why I can't find the three settings on the curve function. If it doesn't hold my hand and tell me explicitly, I'm often clueless, although I poke around enough that I eventually usually find what I'm looking for after some time. I just did not see where one can choose an inclination option. There is a lot of other stuff I have scratched my head over that is user error on my part as well. Like, when I have two media devices plugged into the supplied USB-c slots, I can't toggle between them like I could on my GLC 43 (media interface 1, media interface 2, etc.) It says in the manual that only the one plugged in first works. This is crazy to me that you can't toggle between them as a menu item, although now I am beginning to think I just don't think creatively enough to solve the problem. I'm even too stupid for my smartphone.
Oh, and as always, THANKS GREG!
