New GLE has different Lug bolts
Old Jan 16, 2020 | 06:48 PM
  #126
Henry Stark's Avatar
GLC63S
Anyone have issues with tpms sensors not registering right away. As the other mb products I’ve owned I reset it in the service menu but it tells me nothing detected?
Old Jan 16, 2020 | 07:32 PM
  #127
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
TPMS
You're talking about new sensors on your Winter wheels? I did not have any problem.
Old Jan 16, 2020 | 07:42 PM
  #128
GLC63S
Yeah, it’s mad at me and can’t find them? Won’t even let me back into the tire menu?
Old Jan 17, 2020 | 10:53 AM
  #129
TPMS inoperative
So you bought them from the dealer, right? Not sure if Mercedes uses sensors with other frequencies than 433 Mhz. You might check the part number to verify.
Old Jan 17, 2020 | 09:18 PM
  #130
GLC63S
Part number: 000-905-00-30 I think they are 433 but dealer is saying they are the wrong part number? I have a feeling it’s the car not the sensors?
Old Jan 18, 2020 | 01:07 PM
  #131
TPMS issue
If the system was working with your OEM wheels and not now, it's likely the valves, but that part number is for the correct 433 Mhz. What part number is the dealer suggesting?
Old Jan 18, 2020 | 03:46 PM
  #132
GLC63S
I think it was
A0009054104
Old Jan 18, 2020 | 04:16 PM
  #133
I think it was
A0009054104
I don’t understand. Where did you buy the ones you have now?
Old Jan 18, 2020 | 04:41 PM
  #134
GLC63S
From the dealership. I have it booked in on Tuesday. I figure the car just had a heart attack.
Old Jan 18, 2020 | 06:31 PM
  #135
TPMS issue
So the dealer you bought them from says they sold you the wrong parts? The new number does list the V167 as an application.:
https://www.kunzmann.de/shop/en/tire...0009054104.htm
Old Jan 21, 2020 | 05:55 AM
  #136
tinman831's Avatar
2020 GLE
Its possible that the wrong Tmps sensors were installed.
Old Jan 21, 2020 | 04:31 PM
  #137
GLC63S
According to the dealer the old sensors are not compatible. And the new style sensors won’t fit my “aftermarket” wheels. I’m not really buying it. I’m off to try aftermarket sensors with my after market wheels! What BS
Old Jan 21, 2020 | 05:34 PM
  #138
TPMS issue
I got mine through The Tire Rack, which of course also sells aftermarket wheels.
Old Jan 28, 2020 | 12:12 PM
  #139
hyoshin0724's Avatar
2020 GLE 350
would amg have different center hole? I bought this amb red cap https://www.buymercedespartsnow.com/...xoCNq8QAvD_BwE
but does not fit my 2020 GLE 350 4Matic.
Old Jan 28, 2020 | 12:18 PM
  #140
Hub cap size
No, 2020 hub caps are smaller than previous for some reason.
Old Jan 28, 2020 | 12:20 PM
  #141
2020 GLE 350
Thank you Greg, but do you know any raised red cap would fit in smaller 2020? -John
Old Jan 28, 2020 | 12:52 PM
  #142
AMG hub caps
Since the 2020 AMG models are not out yet (or just coming out like in Canada), I don't think so, unless China is knocking some off. It appears there will be a raised cap option for the GLE 53 Coupe as seen in this photo. This one is black, but I would guess red will be available. Check with your dealer or back to buymercedesparts.com.
These are not for 2020, I don't believe: https://www.mbusa.com/mercedes/acces...rtNo:B66470201
Old Jan 28, 2020 | 01:17 PM
  #143
2020 GLE 350
I have spent the whole week being confused about this! Thank you soo much for this info! -John
Old Jan 28, 2020 | 01:25 PM
  #144
Wheel hub cap size
Though the hub size for 2020s is the same as for 2019s (65.56mm) the old ones flared out to a larger 75mm cap, as you can sort of see in this pic of my W166 wheel hub. The new wheels hubs appear to have the same diameter inside and out.
Old Mar 1, 2020 | 07:30 PM
  #145
Deleted.
Old Mar 7, 2020 | 06:19 PM
  #146
mechia's Avatar
GLE
I recently bought and changed out my GLE 450, AMG 20s, to the 21s rims of the GLE 53 (V167). The rims looks great and at least there were no issues there.
But as part of the order I wanted a new centre cap, I discovered that didn’t fit, as what others here have been saying, the fitting of the cap that came with the factory wheels is just a little smaller than the 66.8mm size indicated on some websites.
In the end I had to settle using the factory (chrome) bolts and centre cap on the new 21s and they fit fine. I am still trying to source black bolts for these wheels.
Old May 21, 2022 | 01:16 PM
  #147
elliotpat's Avatar
Mersedes
I also noticed that the new GLE has different Lug screws. I also bought my new GLE. I was very excited about my new car, but the fact that the screws have changed maybe a crazy situation for many Mercedes fans. In my case, it is less different. This was not a big problem because I also found a wide variety of screws in the online store where I bought the wire balustrade. So finding the right screws for the new GLE won't be a big deal for me.
Old May 24, 2022 | 03:54 AM
  #148
IconBycon's Avatar
GLE 450
Lug bolts
Hard to imagine that was done at the factory. The good news is a replacement is only $7.30. I use an impact wrench with the flower head socket (not for final tightening) with no damage.
What is the OEM part # for the silver ones (NOT Black)?
I'd like to have some spares.
Old May 24, 2022 | 11:43 AM
  #149
Kug bolt
https://www.fcpeuro.com/products/mer...mer-0009905407
Old May 24, 2022 | 01:26 PM
  #150
IconBycon's Avatar
GLE 450
Thank you for the info!
I was about to order, but then I was looking for the part # in Google images, it seems that it is not exactly our Lug bolt, does not have the floating collar and the beefier part next to the threads.
The images on some of the parts suppliers are generic.
Is there a way to find out the correct part # with a corresponding image?
Did you actually order these specific ones?
If yes, that would be reassuring
