Questions on 19" and 20" Wheels
Old Jun 22, 2019 | 01:09 AM
pstwo's Avatar
bmw
The roads here have tons of potholes so we want the tires/wheels to be somewhat resistant to these potholes.
From MB website, I see that GLE450 standard tires are 255/50R19, optional AMG tires are 275/50R20. So the 20" tires are actually higher profile (1 cm thicker). My question is ---- Is the 20" worse than 19" for potholes even when the 20" tires are higher profile ?
thanks !
Old Jun 22, 2019 | 01:13 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Wheel/tire options
You are correct that because the sidewall height is a ratio of the width, and the 255s and 275s are both 50-series, the 20s will have more sidewall height (or cushion if you will). While the width may have some impact on ride, I believe that sidewall height is the main factor. I would definitely go with one of the 20" options: 50R or RZV/RZW. Your choice will be determined by whether you opt for the AMG Line Exterior package; that comes with bigger front brakes that will not work with the 19s. Aside from ride, the 19s look really puny on this vehicle, IMO.
Old Jun 22, 2019 | 02:25 PM
DaveD9's Avatar
GLE 450 / E450 Cabriolet
I think Greg just called my wheels puny!
Old Jun 22, 2019 | 03:20 PM
Wheel/tire options
Don't take it personally! Just my (and several others) opinion that they are a little small for the car visually. When you get new tires I would suggest going to 265/50-19.
Old Jun 22, 2019 | 03:25 PM
DaveD9's Avatar
They are small! I stayed with the 19" as I was thinking my 2016 Blizzak's on rims would work for winter. Following your rim conversion project closely!
Old Jun 22, 2019 | 03:33 PM
Wheel/tire options
I will post a complete write up on that as I get everything checked out. I'm hoping before Fall the aftermarket catches up with extended lugs and spacers.
Old Jun 22, 2019 | 04:30 PM
pstwo's Avatar
bmw
Thank you very much Greg ! This helps a lot
Old Jun 22, 2019 | 08:15 PM
Wheel/tire options
Well, ideally you have two sets of wheels so aren't dismounting and mounting twice a year. That's what I've always done. You might find some 20" takeoffs down the line as more of these get in the market.
Old Jun 22, 2019 | 10:09 PM
DaveD9's Avatar
Yes, always have used two set of rims and fortunately we have a tire shop that stores them for next to nothing in cost.
