Winter Tires - What are you wearing?
Old Nov 2, 2019 | 08:54 AM
  #76
DaveD9's Avatar
GLE 450 / E450 Cabriolet
Blizzak 255/50R. DM V2. XL 19". on 19x9 MSW Rims
Old Nov 2, 2019 | 02:04 PM
  #77
Henry Stark's Avatar
GLC63S
Looks good Dave! How much space do you have between the caliper and the wheel?
Old Nov 2, 2019 | 02:20 PM
  #78
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Winter tires for GLE
I think I would have gone with 255/55-19; their 30" diameter is closer to the rest of the GLE's tire options (more pothole cushioning). Heck you could even go 60-series. For some reason the stock 19" size is puny compare do the others.
255/50-19 - 29.1"
255/55-19 - 30.0"
255/60-19 - 31.1"
275/50-20 - 30.9"
275/45-21 - 30.8"
Old Nov 2, 2019 | 03:12 PM
  #79
GLC63S
255/50-19 - 29.1"
255/55-19 - 30.0"
255/60-19 - 31.1"
275/50-20 - 30.9"
275/45-21 - 30.8"
I think Dave’s stock tires were 255/50’s and switching them would probably require some sort of software update not sure how this wouldn’t mess everything up if there wasn’t. Maybe something to do with steel springs vs. air? Even tire rack shows this size available to all models so they are probably unaware also?
Old Nov 2, 2019 | 03:50 PM
  #80
Winter tire size options
It would be interesting to know if the speedometers are calibrated to the tire size as delivered. If so, it should be programmable. The difference in revs/mile between 255/50 & 55-19 is only 3.3% (716 vs. 693).
Old Nov 2, 2019 | 03:55 PM
  #81
bob01's Avatar
2009, 2012 ml, 2016 gle350d, 2020 gle450
Winters were fitted yesterday - wheel package from the dealer w/ 275/50/R20 Pirelli Scorpion.
Ride is slightly more comfortable than the 275/315 21's that they replaced but handling is mushy (of course) - won't matter in the next few days - first snow expected next week.
Might look into some sort of spacer for the rear wheels next time - they look lost back there.
Old Nov 2, 2019 | 04:04 PM
  #82
GLC63S
I remember when I shopped around for wheels for our Volvo one of the oem accessory options required software change.
Note!
When changing to another approved tyre dimension, the application for steering deflection limiter and/or speedometer may be needed. Contact your local Volvo dealer for more information.
Old Nov 2, 2019 | 04:16 PM
  #83
DaveD9's Avatar
GregW "I think I would have gone with 255/55-19; their 30" diameter is closer to the rest of the GLE's tire options (more pothole cushioning). Heck you could even go 60-series. For some reason the stock 19" size is puny compare do the others."
I was waiting for the puny comment again
May have been something to look at as our potholes are more like craters. I-800-POT-HOLE is a speed dial on my phone to the NYS DOT. The good news is they respond quickly.
Old Nov 2, 2019 | 05:20 PM
  #84
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Got my Michelin Pilot Alpin P5’s installed today. I was able to use the lug bolts from Otis mentioned previously by Henry. I bought the longer ones, 33mm.
But I continue to have a brain cramp with offsets and miscalculated the positioning that 8 1/2” wheels with et45 would have on the front tire location. There was no noticeable difference in the upper tread and tire bulge location from stock 9” wheels with tires the same size as stock. These are very large tires and sucking in the bead does not make them narrower. If there is any difference it is very negligible.
Now on offsets....less offset moves the outside Wheel edge out-not in. The offset is from center and I know better but continue to get it wrong until thinking about it. This came up early in the thread and is the reason I didn’t buy Titanium extended length bolts and spacers. Promptly forgot!
So I’m glad I went with et45 instead of using my et32’s. I measured from the widest point of tire bulge before and after using a level along the wheel trim. This is not exact but close enough for my purposes. My new tire at the widest bulge moved out beyond the trim more than 1/4” - they were just about 1/16 inside with factory tires and wheels. The tread is still inside the fender.
The net change shouldn’t cause any rubbing but will slightly increase mud and debris on the body. I found some mud flaps for the 167 GLE with AMG, shipping from China 3 weeks out. I’ll post pics and fitment when they arrive. They are small and won’t offer much protection (if they fit).
Anyone considering spacers might want to double check their wheel offset and calculations.
Here are a couple of pics.
Old Nov 2, 2019 | 06:42 PM
  #85
Ron.s's Avatar
I forgot to mention the Tire Rack TPMS sensors work perfectly. I don’t know if they were reset by Costco or if they reset by themselves. They show pressure and temps like OEM. I like the temp feature. It will give me a chance to see how if the Nitrogen reduces temps over those with air. There were some wide swings with factory tires, running over 100 degrees in 50-60 degree ambient.
Old Nov 2, 2019 | 06:51 PM
  #86
I was waiting for the puny comment again .
Sometimes size matters! 😃
Old Nov 2, 2019 | 06:53 PM
  #87
GLC63S
How did the rears end up? Did you note how much of the lugs protruded from the back of the wheel?
Old Nov 2, 2019 | 07:02 PM
  #88
Winter wheel offets
Stock offset for 8 1/2s is et42 in the rear, so his et45s should be just about spot on with the wider tires. I'm using my W166 20x9s that are et57, which is exact spec for the 9" fronts and with 12mm spacers will be within 1mm in the rear.
Old Nov 2, 2019 | 07:25 PM
  #89
Ron.s's Avatar
The rear is so close that I couldn’t measure any difference at the bulge.
I didn’t observe the install but gave them the option to use the shorter Tire Rack bolts if they were too long. If I get some free time later in the week I’ll pull a wheel.
Old Nov 2, 2019 | 07:35 PM
  #90
GLC63S
Thanks Ron
Old Nov 2, 2019 | 08:54 PM
  #91
Ron.s's Avatar
Thanks Ron
Watching a Football game and accidentally erased the part “except for the 1/4” from narrower wheels”. The 8 1/2” rear wheel is inboard 1/4” from the 9” but the 1mm diff in offset didn’t make enough dif. to measure.
This helped reduce the front wheel offset that was 13mm or a little over 1/2” to just over 1/4” outboard from stock. Sorry for the omission.
Old Nov 3, 2019 | 01:56 PM
  #92
GLC63S
What did everyone end up suing for tmps sensors. I bought the hard ones from dealer but when I was by earlier they all switched to the rubber stems? Hope the ones I bought work should be same freq?
Old Nov 3, 2019 | 02:14 PM
  #93
DaveD9's Avatar
Got my TPMS with the package from Tirerack.
Old Nov 3, 2019 | 02:17 PM
  #94
TPMS sensors
I got the 433Mhz ones from The Tire Rack ($40 each) - they are a hard stem.
Old Nov 3, 2019 | 05:17 PM
  #95
GLC63S
Thanks guys. I have a lead on some locking wheel bolts I will let you know how it pans out.
Old Nov 3, 2019 | 09:55 PM
  #96
Ron.s's Avatar
I got some road miles on the Michelin Pilot Alpin P5 tires today. They are very quiet maybe more so than the factory Michelin Primacy Tour AS. Even on a rough seal coated road they seem smooth and fairly quiet. I assume they are as good or better than the Xi2’s I’ve run on other vehicles. I’m in no hurry to try them in snow and ice but that’s coming soon.
I snapped a picture of how the new wheels look on my car. I like the look of the wheels but might get tired of cleaning all of the spokes!
Old Nov 3, 2019 | 10:01 PM
  #97
Wheel cleaning
Cleaning is really easy with the right brushes:
Boars hair wheel brush: https://www.autopia-carcare.com/mont...l#.XVl6BehKgkE
Wheel brush: https://www.griotsgarage.com/product...ks&from=Search
Tire scrubbing brush: https://www.autopia-carcare.com/moth...l#.XVl67ehKgkE
This wheel brush is especially good between the spokes:
Old Nov 3, 2019 | 10:58 PM
  #98
Ron.s's Avatar
I’ve got the tools but it still takes time and isn’t that much fun in winter. Add the wheels to the job of cleaning all the ridges on the lower AMG body trim and at least bi-weekly cleaning..... I’ve never had a car that threw so much crap on the sides and fenders. Mud flaps are my next project.
Old Nov 4, 2019 | 10:10 AM
  #99
tommyr's Avatar
25 GLE53, 24 Macan, 15 GLK350
Can anyone who bought winter rims from Mercedes confirm what size socket is needed for the lug bolts they supply with their rims?
Old Nov 4, 2019 | 11:27 AM
  #100
Lug socket
17mm is standard size. Do the Mercedes Winter wheels not use the standard lug bolts? If the standard "flower head" bolt, you should get one of these (https://www.ultimategarage.com/shop/...oducts_id=8303):
