Speed limit sign assistance
My A220 has a feature where it shows the speed limit (based on the front-facing camera detecting speed limit signs) and shows it on the dash. I can't find that feature for our new 2020 GLE. It's under the Settings -> Assistance section on my A class. I don't see the same option for my GLE. Does anyone have this feature? If so, do you know how to enable it?
It's called Speed Limit Assist and it's a $295 option for the GLE. Does your car have that option? Alternatively, it's part of the Driver Assistance Package PLUS, which also adds Active Speed Limit Assist. The latter automatically adopts the detected speed limit for DISTRONIC.
“Traffic Sign Assist can detect posted speed-limit signs and, along with information in the navigation system's map database, display the limit on the dash. It can also alert you when you exceed the limit.”
I believe in MBUX it is referred to as Traffic Sign Assist, since I occasionally get warnings that it isn’t functioning at a particular moment. If you’re having difficulty locating information on Speed Limit Assist in the manual, try looking for Traffic Sign Assist. It may help, Good luck.
Pressing RESUME manually adopts the current speed limit, but then subsequently it should automatically adopt new speed limits. You can turn off the automatic speed limit adoption. I did European Delivery and had it turned on in Europe as speed limits change frequently and they are taken more seriously. Saved me from getting speeding tickets for the most part, but in Europe it had the same issue occasionally as they also have speed limit signs on the back of trucks etc., so occasionally it started to slow down if it read one of those. Here back in the USA I turned it off and only use the manual function using RESUME. Speed limits don't change that frequently here and compared to Europe, they are more of a guideline. It's very common for traffic to go 10 or even 20 over the speed limit, but I still like the manual adoption method of the speed limit so I can set it quickly to the current speed limit and then increase it from there.
