high-pitched whistling sound
(since you use an o-ring that is 0.139", I assume the gap on your mirror is larger)
Edit-Looking at the picture again it looks like you just did the top 1/2 of the mirror so what keeps it in place? Seems like it might hold better making a joined piece.
Splicing o-ring material is simple. You can buy splice kits. Or for this application simply superglue the ends. But if the material stays in place why bother?
After installing this fix the other day I drove about 150 miles on the interstate highway at speeds between 55 and 80 mph. No whistle. The o-ring material stayed in place.
I have only owned my GLE350 for about a month. This noise started driving me nuts the first time I drove on the highway.. I as and still am very pissed about buying a $70k MB that has this type of issue. I shouldn't have to MacGyver a fix on a new, expensive vehicle. I will be bringing this attention to my MB Service Manager. MB needs to fix this problem permanently.. But until then I am very happy that my GLE isn't whistling . and I can enjoy driving it.
What I hate about mirrors in general is the water dripping constantly after a wash job. It’s just the nature of having adjustable parts and clearance for the folding and tilt function. Looking foreword to the day when a camera replaces the mirror....
thanks!
Very good news. First of all, let me tell you guys that the problem has been solved! They replace the driver's side mirror cap. See the attached screenshot of the detailed explanation from the dealer. I drove the car very on a windy day, I was lucky that the day was windy
No noise at all. What i also realized that between the mirror cap and the black frame, there was a larger gap before they replace it, and now the gap is much smaller. Probably that was the problem. If your dealer cant solve it let them call Fletcher Jones Newport Beach. My service advisor was Ray. Let me know if you have guys have any questions.
I want to provide an update as I went to the same dealer/advisor after hearing from oakpek of his successful fix. My GLS with the same whistling sound was at the dealer for a week. For oakpek, his changing of the mirror cover + probably adding some felt in the seams worked, but it did not for me. They then proceeded to change a seal in the mirror, which also didn't work. Lastly they swapped out the entire mirror frame (the part where the mirror attaches to the door) and according to the tech it reduced the noise, but not fully gone. They were pretty much out of options at this point and opened a case with corporate MB, when the engineers instructed them where to place additional felt and apparently gave them specific instructions on how to put the whole mirror assembly back together. I'm not really convinced swapping the mirror cover helped in my case and it was more of placing felt and foam insulation at strategic locations and possibly changing out the mirror frame. But anyhow, they told me the noise was gone and after driving it for a day I think its 85-90% gone. I think I sometimes hear it if I try really hard with radio and A/C off, but I cannot be too sure if its really the sound or my brain is playing tricks on me now. Regardless, the sound is definitely much better for now and I will continue to look out for it. So thank you oakpek!!
I also see the O-ring fix, which I am tempted to try out too since you won't be able to tell. However, if I am remembering correctly, from speaking with my original service advisor the gap is there for the wind to deflect water off the driver's side window and is actually a safety feature. I'm not 100% sure of this but I would think adding the O-zone piece would interfere with the performance of the safety feature. Not that this is a critical safety feature or something more important than saving your ears from the permanent damage of the damn noise, but I would be aware of this if anybody were to add it.
Maybe before doing the O-ring fix it would be wise to have your service advisor to open a case with corporate MB engineers as it seems like they are aware of the issue and have experience in getting the noise away without touching the gap on the mirror.
Next time I drive my GLE in the rain I'll check to see if the o-ring fix has had any impact on water hitting the side window. The o-ring is easy to install and remove. My opinion is the whistling noise is way more of a distraction/annoyance than a little extra rain splashing on my door window.
The more I read in this forum the more I think that MB has a manufacturing issue with the mirrors. Some whistle and some don't. And the whistle varies in pitch and loudness. I think the gap is out of design tolerance on the ones that whistle. Changing out the mirror might get you one that is in or closer to the design requirements.
I'd really like to hear the opinion of a MB Design Engineer. MB needs to address this problem.
I havent noticed it lately, I am thinking it might br that I have changes the angle of it or that it went to the dealer to fix the hood as it wasnt closing properly on one side.
had a trip now. I still have it over 120 kmh.
but hardly there
Interestingly, as part of the first 10K maintenance, they changed all the wipers. That is nice.
i do plan on complaining to MB next time I take my GLE in for service. There has got to be a real fix for this problem.
Best of luck.
E CLIENT STATES HEARING A WIND NOISE AT HIGHWAY SPEEDS AT ABOUT 60-70
MPH
NC NO CHARGE
70607 INC (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE E: 0.00
2967 N/C PERFORM TEST DRIVE TO CHECK FOR ABNORMAL WIND NOISE. THE
NOISE SEEMS TO BE WIND TURBULENCE BUT NOT VERY EXCESSIVE. APPLY MASKING
TAPES AROUND MIRROR HOUSING AND DRIVER DOOR AND HANDLE AND A-PILLAR
AREA. RETEST DRIVE VEHICLE AND NO CHANGES IN WIND TURBULENCE. TEST
DROVE ANOTHER VEHICLE WITH SAME CHASSIS AND BODY STYLE AND VERY SIMILAR
NOISE IS HEARD. UNABLE TO PERFORM ANY REPAIR AT THIS.
MPH
NC NO CHARGE
70607 INC (N/C)
My point is if you have other dealerships within your area I would definitely go get a second or third opinion until one dealership is willing to fix it for you, or at least try to. Even though this issue is a mirror cover design issue, it doesn't mean they cant open it up and add felt or at least try to do something to it. The designs are the same, but I am assuming tolerances are different, hence people are getting different resolutions for this problem. I know some people stay "loyal" to their service advisor, but if one dealership won't fix it doesn't mean another one will do the same.
