Memory Seats
Old Jun 11, 2020 | 10:02 AM
jmrwd3's Avatar
GLE 350
Memory Seats
Occasionally, the MBUX profile screen is very slow to come up, and the three drivers in our family have a substantial difference in height, to the point that it’s impossible to get into the car without adjust the seats. I’ve tried everything to program the door mounted memory seats to function as a workaround, and they seem to accept programming (acoustic confirmation) but do not respond. The only time I’ve had them successfully function is when the profile has failed to restore memory settings. Then the door button mysteriously worked! Any ideas?
Old Jun 11, 2020 | 12:05 PM
zengshengliu's Avatar
2020 Mercedes GLE 450
Did you program the memory seat option (on door) on the same profile? Each profile has its own set of memory seat settings, so the Profile A seat 1/2/3 setting is different from Profile B seat 1/2/3 setting.
Old Jun 11, 2020 | 07:20 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Yes, with 3 drivers, program the buttons in all 3 profiles to make sure they work.
Old Jun 11, 2020 | 10:15 PM
jmrwd3's Avatar
GLE 350
Thank you!! This was exactly it, didn’t even think the 3 buttons would be per profile, easy workaround definitely appreciate the help!
Old Dec 27, 2020 | 05:17 PM
Crispin's Avatar
Top Answer: 1
2016 GLE350 4matic
Hold the phone! I got the same problem as the OP.
I'm trying to figure out what you guys are saying here. There are two profiles in the car, C and G and Guest. There are three buttons on the door 1, 2, and 3. You're saying that I have three seat positions for profile C and three for profile G? Why would you need that?
But anyway, I open the door and press one of those three buttons, how does it know what profile to use for the settings? What if the wife gets to the passenger door and unlocks it with her key in the purse first?
How do you program the buttons anyway?
Old Dec 27, 2020 | 05:53 PM
Memory buttons
There are three profiles. The three memory buttons can be configured differently for each of the three profiles.
The button will respond to whatever profile is active in the MBUX. Profiles are not key-dependent.
Get seat position & contour, outside mirrors, steering column & head up display manually configured how you want them, press the "M" button then one of the 3 buttons you want to program. You can do this for each profile. It works with ignition off, so handy, for instance, if my wife's profile is active and the seat is far forward I can press m button on the memory and it will move the seat back before I get in and change the profile.
IMO, the MBUX system and controls in general are way more complex than they need to be. I am probably more tech savvy than 75% of owners and given that it's not my DD I still need to look things up or remember how to do something. I get the feeling that the geeks that design the systems don't actually get feedback from real owners. I think the complexity is a disservice and actually decreases the vehicle satisfaction for the majority.
Old May 12, 2021 | 02:15 PM
boltsfan's Avatar
2021 GLE 350
So if you click memory #1 on the door to move seat to your position and then click your Profile once you sit down on MBUX... the Profile also stores the seat memory independent of the door memory which is not intuitive. I don't think they sync from what I can tell hence all the confusion.
When setting up my Profile in MBUX it sets the seat, steering wheel and mirrors. What benefit would it be to set the door memory to any number under my Profile if I need to use my wife's Profile to move the seat to a position that I need in order to sit down.
Old May 12, 2021 | 03:57 PM
mikapen's Avatar
I thought I had this figured out, then I received a notice on Mercedes Me that there had been an update. Now things behave differently, and I now have the same question you just stated. It's a two person job!
Old May 12, 2021 | 04:55 PM
Useful to do a quick adjust when getting in, like when my much shorter wife has the seat forward, then selecting your profile will do a final tune. You each need to set the of the door buttons under each profile, though.
Old Dec 20, 2022 | 06:22 PM
GroovyGeek's Avatar
GLC300
Selecting a profile does NOT move the seats, at least not on my wife's '21 GLC. If I am missing something please please point me in the right direction because I am learning how to swear I German so I can tell the engineers who designed this what I think of their work 😄
Old Dec 20, 2022 | 06:33 PM
Profiles and seat settings
Not sure what your issue is, but you save seat and mirror settings (among other things) to a profile, and they are then recalled when that profile is selected. Works for us every time. If you don't have a memory passenger seat it will not be adjusted.
Old Dec 20, 2022 | 08:04 PM
GroovyGeek's Avatar
GLC300
This is also what the GLC manual says on p.246 but this is absolutely not what the vehicle does. At least not consistently. I am sitting in the car as I write this and tested it and literally nothing happens as I switch profiles. I even adjusted seat positions in between switches and nothing is happening.
This is my wife's car and she seems to be in no hurry to take it to the dealership, so in the mean time it is just an annoyance for me. I drive they car less than once a month.
Old Dec 20, 2022 | 08:29 PM
It could be the settings were not correctly saved. Go through the procedure again. I wish you could just get everything set how you like it and press one button.
Old Dec 22, 2022 | 06:22 AM
mykel79's Avatar
GLE
Do you have the doors closed? I think it doesn't move the seat if the door is open when you're changing the profile.
Old Dec 22, 2022 | 11:13 AM
GroovyGeek's Avatar
GLC300
Checked with the dealer and was told that all GLCs do not have seat memory via profile. The only way to adjust the seats is via the memory buttons on the doors. Truly astounding... Thank god this is my wife's car, because I don't think I would ever be buying a MBZ. Can't afford the mid to upper end of the class and the GLC/C class and below are absolutely not worth what you pay for them.
Old Nov 20, 2024 | 07:54 PM
azegarek's Avatar
E350 Sedan, GLE 350
Seat positions and user profiles
We just acquired a 2024 E350. My wife and I both drive the car and require different seat positions. In our old 2007 eclass we could just choose our seat position on the door, get in the car and drive. Now invariably, whenever the driver changes, the seat moves to the position of the last person who drove it, even if the door button was pressed when the door was first opened. If my wife drove the car last I cannot get in unless I move the seat back. So I press the button I saved on the door to
love the seat to my desired position. Then when I go to start the car it remembers that she drove last under the chosen profile (which is no profile selected) and starts to squish me in the seat; I have to move it back a 2nd time with the door button. Then if my wife drives after me the reverse happens.
This is a terrible design. If a person presses a seat position button then do NOT automatically move the seat because you are so sure that the same real human is driving using the active profile (or no profile which as far as I can tell is treated like an active profile) as the last time the car was driven. This is just so annoying.
Old Nov 21, 2024 | 02:13 AM
mykel79's Avatar
GLE
With a big height difference between drivers this behavior really is annoying. Maybe you could switch to using your own profiles? Then instead of pushing the button on the door your could reach in and pick a different profile on the center screen. The seats and mirrors will move accordingly. No need to use the buttons on the door.
It really is handy to have your own profile. You can set your own lighting colors, easy exit settings, belt tightening, delayed external light, etc. I mean, my wife likes pink internal lighting but I definitely prefer some other color 🙂
Old Nov 21, 2024 | 08:34 AM
parato's Avatar
2024 GLE 450e
All MB needs to do is make the profiles key dependent like BMW does. When I walk up to my BMW it recognizes me from 10 ft away and changes the profile before I reach the door.
Old Nov 22, 2024 | 01:51 AM
mikapen's Avatar
If you are in the correct forum, a GLE350 shouldn't behave that way. It should go to the memory position you punch and stay there.
If you have the settings set to lift the steering wheel and move the seat back for exit - then return after seating - that's a different setting that you can turn off.
I'm a bit unclear what you're describing, but you should document your sequence, including other buttons or adjustments you make, and give it to your Dealer.
