Seat Kinetics
Old Jun 11, 2020 | 04:03 PM
monwen's Avatar
bmw 535i xdrive
Seat Kinetics
Someone explain what this setting is or how to activate it? It's a setting under COMFORT.
Old Jun 11, 2020 | 04:09 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
It's an annoying routine that causes the seat to shift a little randomly. The lumbar mostly.
Old Jun 11, 2020 | 04:11 PM
monwen's Avatar
bmw 535i xdrive
How do you activate it?
Old Jun 11, 2020 | 04:15 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
It's in the Comfort settings group seat comfort...Seat Kinetics. touch the play arrow to turn it on
Old Jun 11, 2020 | 04:16 PM
monwen's Avatar
bmw 535i xdrive
I'll have to try it out. Sounds like it may be good for a long ride and thanks for the quick reply.
Old Jun 11, 2020 | 06:57 PM
monwen's Avatar
bmw 535i xdrive
Is the seat kinetic only available for the driver?
Old Jun 11, 2020 | 07:15 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Seat kinetics
No, both seats in mine. I find it not all that compelling. Might be good after 3 straight hours of driving. Will try it again on a long trip I'm taking next week.
Old Jun 11, 2020 | 07:26 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
That depends on if the passenger seat has the power lumbar. My dealer said the passenger seat shows up in the settings even though it's not available and that was on the fix list for a future software update.
Old Jun 11, 2020 | 07:52 PM
monwen's Avatar
bmw 535i xdrive
The power lumbar being the control at the side/bottom of the seat? If so, my car does have it.
Old Jun 11, 2020 | 09:26 PM
MercOne1's Avatar
2020 GLC43 | 2020 GLE350 | 2014 E350 (sold)
Terrible feature that moves the seat position significantly while driving. Very unsettling. Just use the massage feature instead.
Old Jun 12, 2020 | 01:47 PM
tiri's Avatar
2020 GLE450 4Matic AMG-Line
I use the kinetic seats regularly. I really like it.
Old Jun 12, 2020 | 01:50 PM
monwen's Avatar
bmw 535i xdrive
I like it as well; ever better than the massage seats that I have in my other car. Haven't been able to figure out how to make it work on the passenger side. Have you tried it on the passenger side yet?
Old Jun 12, 2020 | 02:04 PM
tiri's Avatar
Passenger seat kinetics require memory seat function.
To activate it, as was mentioned earlier, you go to the Comfort Flower icon, and under it, there are two options. Tap the left one, and then the next screen shows you the two seats. each one has a "PLAY" Triangle.
Old Jun 12, 2020 | 02:06 PM
I think perhaps you need option P64, Passenger Seat Memory - do you have that? I do and both seats are selectable on mine.
monwen's Avatar
bmw 535i xdrive
Thanks; that's the reason. Only have memory on the driver side.
Old Jun 12, 2020 | 02:07 PM
They order guide should be clearer on this.
Old Jun 12, 2020 | 05:19 PM
user 7208224's Avatar
2020 GLE 350
I found that the easiest way to activate it is to use a voice command. "Turn on seat kinetics" Simple. I use it on longer trips. The seat motions are more subtle but they keep you from getting stiff. If you want to really feel something more pronounced, use the massaging feature if you have it.
Old Jun 12, 2020 | 05:51 PM
monwen's Avatar
bmw 535i xdrive
Thanks. Good idea to use voice activation.
Old Nov 19, 2021 | 05:02 PM
Schwarzman01's Avatar
2021 GLE 350 SUV
Seat Kinetics
Do you always have to go into Comfort Setting to turn on OR can you turn it on when creating a theme? That way anytime you select the then it’s activated?
Old Nov 20, 2021 | 04:56 AM
royal1262's Avatar
2022 Mercedes benz GLE 53 AMG
Can you use both seat kinetics/massage together? Ordered the 450 but changing to the 53 and will be adding the message feature. Thanks
Old Nov 20, 2021 | 08:48 PM
2020 GLE 350
I have never tried using them both at the same time, but my guess is that they would not work that way. The massaging seat function will turn off after a period of use. The seat kinetics will continue working until you stop it. I use the feature on long trips.
Old Nov 20, 2021 | 09:02 PM
royal1262's Avatar
Thanks!
Old Nov 20, 2021 | 09:04 PM
royal1262's Avatar
Is the massage seats worth it? Are they any good?
Old Nov 20, 2021 | 11:11 PM
Williemv's Avatar
2021 GLE Coupe
yes you can, they can operate at the same time.
Old Nov 20, 2021 | 11:17 PM
royal1262's Avatar
Thanks!
