GLE 350 4MATIC - Different wheels impact on driving
Did anyone drive the GLE 350 4 MATIC 2021 with 19inch wheels vs 21inch wheels ?
I drove the 21 one and find the ride pretty bumpy on New York roads (potholes etc ...). I was wondering if getting the 19inch would make a noticeable difference in the driving feeling (smoother) ?
Thanks for your help.
- 255/50-19 = 127.5mm sidewall
- 275/50-20 = 137.5mm sidewall
- 275/45-21 = 123.75mm sidewall
Now you could put 55 or 60 aspect ratio 19s on, but the stock size is ridiculously small (look it on the vehicle, too).
But you might change your mind about Cooper if you have driven the MO Cooper tires. They are a new generation, new tech, new compounds, and perform better than the Pirelli's, IMO. I have driven @1,500 miles on them, 500 miles on 20" Pirelli and 500 miles on 19" Pirelli's, all on 2020 GLE's. I prefer the Coopers, especially for fun driving.
As always, you can't judge a tire until it has a few hundred miles, after the release agent has worn off and the tires are scuffed in. That would eliminate opinions on new tires on the Dealer's lot, unfortunate for those of us who like to assess a tire's performance.
The new run-flats are also much improved over previous generations - I have been surprised in the offerings over the last two years. I will be taking the Pirelli run-flats off the '19 GLC this week, for Nokians. Not because of ride or traction - but we're going into snow country.
With previous cars, I exchanged the run-flats with Go-Flats, at the Dealer before delivery, but saw no need on the GLC. That surprised the heck out of me!
I might suck it up and use the coopers if the car came with it, but in no way will I accept run flats. Nor should the OP.
The "bulge" you are talking about has an inverse relationship to both handling and impact damage, although a bigger "bulge" will guard the rim in a parking lot. Best to honor the manufacturers' recommendations here.
That article does mention that wider tires also contribute to tramlining. Not sure about the impact of breakaway.
Are you saying that you are ranking them like this in term of ride comfort ?
1. 20" (smoothest ride)
2. 19"
3. 21"
That said, a test drive could refute these theories. If the 20 and 19 drive similarly, it would then be a matter of looks vs tire replacement costs (the 19s would be slightly cheaper). In addition, the narrower 19” would hydroplane less and drive better in the snow.
I have a 2020 GLE 4 Matic With 19 inch rims and Bridgestone Alanza Run flat tires size 255/50/R19. I am very pleased with the ride of these tires but hate the way they look. They definitely look very undersized. I want to see if I could go with the same Bridgestone tires but in a different size 275/55/19 Which are about an inch and a half taller and about an inch wider. Could you please give me some pros and cons, Will I run into any problems with sensors etc.
Also I don’t want to change rim size to a 20 or 21. Also the GLE Has a third row seat so I don’t have a spare any input or advice would be greatly appreciated thank you
By having a smaller sidewall and whatnot, wouldn’t that lead to increased road noise and more of a risk of damaging the rim/tire due to a curb or pothole?
btw.. her tires on 20 in wheels have plenty of sidewall to handle crappy NJ roads. No problems.
