Dashcam
On that note, what other accessories are there that online configurator doesnt show yet you can add? I dont want to miss anything that I should add.
I m assuming you mean DAP = Drivers Assistance Package. This isnt available to order?
PROBLEM
- Mercedes-Benz sells and you probably purchase a factory-installed dashcam that will not Auto record. For the purpose of this post, we will only talk about vehicles purchased and operated inside the USA.
- There is no Mercedes-Benz notification on the window sticker or manual about the factory disabling automatic video recording.
- Furthermore, the onboard electronic manual shows how to activate the feature hence there is no way for you to know this feature is disabled before purchasing the vehicle.
- The missing auto-record feature is analogous to having a clock in the car that needs to have the time set every time you start the engine. Not what you would expect from a world-renowned "The best or nothing," automobile manufacturer.
- The dealer and Mercedes-Benz will attempt to convince you without any evidence that it's illegal for them to activate the auto recorder. This is not true. The dash camera does not record audio or video inside the passenger compartment. The aforementioned recording would be illegal in some states (CA surprised?).
- The Auto-record feature is not working because Mercedes-Benz has not aggressively pursued approval from the NHTSA. Approval is needed because it's a new feature.
- Here is one of many articles on the legality of dashcam recordings. https://www.azuga.com/blog/dashcam-l...ers-and-owners
- Vehicles with the Dashcam 2U1 package are supplied with a "Media Interface adapter cable" but no USB flash drive.
Workaround - You can register the dashcam to 'Favorite' on the center console (the button with a star symbol). Once done, it needs only two clicks without even touching the screen (you need to move the dashcam icon to the leftmost position so you don't need to scroll to the right). Keep in mind this will not resolve the disabled auto-recording feature but gives you a workaround albeit a lot of discipline required to remember to turn it on.
- Once you plug in a USB Flash Drive using the Mercedes-Benz supplied adapter the manual recording may or may not work. In most cases, it works for a while and then stops, becomes intermittent and eventually, the DashCam software in the Mercedes apps disappears. Don't waste your time with the dealer they do not know how to fix the issue. They will factory reset your MBUX software, you will lose all your settings and it will not fix the issue.
- Regardless if you use the workaround or not you might get the following error.
Function Unavailable -
FIX - The fix consists of installing a newer USB Type C aka "sub C" without any adapter. Once you start the engine within a minute the software will appear in your Mercedes apps and you can manually initiate recordings. The wait time will have to be repeated on each use. Here is a photo of the one that worked for me.
- Complain to Mercedes-Benz in writing using this email address. mercedes_benz@mailac.custhelp.com
- When you received the canned response "Thank you for your email to Mercedes-Benz USA. However, we regret to inform you, the vehicle is designed to require manual activation of the dashcam within the US market, etc..." do not accept that as an answer. Request that they raise your request to the level to someone that can authorize enabling the option that was disabled without your knowledge or consent. This will result in a phone call (they don't want it writing) from the Executive Referral Management team. Explain to them your displeasure and frustration. They do not have an answer for "Why was this not disclosed before the purchase?". See if they will send you in writing what efforts have been undertaken to get approval from whatever agency is holding them. If we can get the department number and address we could flood them with letters.
- The more of us complaining the greater the chance of the issue getting fixed as these guys have access to the engineering and legal teams.
- the software is already written to provide the functionality. All they have to do is stop disabling the auto-record feature which can be done via an "over the air" software update.
- The problem you are experiencing was an undisclosed issue that would have changed your mind about the purchase.
- PLEASE Post any new revelations or updates to this thread.
But I am interested in your statement:
- "The Auto-record feature is not working because Mercedes-Benz has not aggressively pursued approval from the NHTSA. Approval is needed because it's a new feature."
I'd appreciate a reference because I may have some input here.
Thanks.
I would add the issue that if you want to play music off USB, selecting USB picks the USB port near the wireless charger where I have the drive for recording and not the port in the armrest compartment where I have my MP3/flac files. Thanks again.
PROBLEM
Thanks.
Assuming we are stuck without it but wondered if anyone has heard/seen of a way to make it work?
