Aftermarket dashcam related questions - noob alert!
I'll be getting Thinkware U1000 dashcam professionally installed (hardwired) soon. But after reading various dashcam related threads here, I have a few questions and hope the people with experience can help me out. I want to be well prepared and don't want any unpleasant surprises.
1) Those of you who installed this particular dashcam on your GLE, was the included wires long enough? I keep reading the included wires are too short for some other models of dashcams.
2) The U1000 has radar accessory for motion detection during parking mode. It also reduces power consumption. I park my car in garage and won't be parking outside for extended periods (unless I'm travelling). Should I get this or is it not necessary in my use case?
3) I understand the wires are usually hidden under the weather stripping or behind panels. Are there any panels that are more difficult to remove? How about clips breaking? I'm just concerned about rattles due to loosely put back panels after the install so I want to keep an eye out.
4) I won't be getting a backup battery as I don't anticipate using the parking mode very often. Have you experienced any car's battery draining issue with having the dashcam hardwired?
I know that's a bunch of questions so thank you in advance!!!
As far as setup goes, I have an external battery (cellink NEO) hooked up and it only charges when the car engine is running. This way my car battery does not get affected at all. I did not get the radar accessory and garage park my car all the time with no issues. I think its a waste of money honestly.
I'm getting mine installed professionally as I'm not talented enough to tackle something like this on my own.
I just wanted to be prepared so I know what to look out for and make sure the shop does a good job.For the backup battery, I was debating on getting one but wasn't sure if I needed it. I won't be using the parking mode for long periods at a time and I think the U1000 has a feature to turn off if the battery voltage drops below a set point. So I was thinking I won't need the backup battery.
I would be interested to hear why you decided to get the backup battery though.
Now, I'm wondering if having a dashcam will affect our warranty? I mean, since there are lots of reported 48V system issues, will the dealer refuse to honor warranty if they see a dashcam connected?
I will occasionally top up the 12V battery with my Ctek battery maintainer but only for peace of mind because I haven't been driving much and not because it actually needs it. I've only topped it up twice in the year that I've owned it, so it's not a regular thing.
It's my understanding that drawing down the 12V battery will not pull any power from the 48V system, so even if you do manage to kill the 12V battery the 48V battery will be fine. The 12V battery is located under the driver's seat and not that difficult to change if you needed to. There's a plastic hatch that you just lift up, unlike the W164s which you had to cut the carpet to access the hatch.
now looking back). Our 12V batteries should not affect the 48V system like another_geek mentioned above and I knew that going in with the external battery with the GLS, but I just wanted to test out the ext. battery and so far I like it. It also gives you prolonged parking recordings, unlike before where my battery voltage would always drop and stop recording very soon after I park.
I'd like to keep my install simple so I'm leaning towards not using a backup battery and I don't want to deal with potential 12V battery issues by hardwiring to a constant hot fuse.
If this is the case, you can consider a cheaper camera because a big reason the U1000 and higher end cameras cost a lot more is because of the parking feature. Adding an external battery is just one extra hookup and wouldn't make the install anymore complicated as its just an attachment between the fuse box and the camera. Of course, granted that you are willing to shell out another $200 or so for the battery.
There are no switched fuses in any of the fuse blocks in the front of the car, so if you want switched power, you will have to run a line all the way to the rear fuse block.
There's an older thread with lots of good info if you want more details on how to install a dashcam Dashcam options - MBWorld.org Forums
With your Celink Neo battery, did you need to purchase any additional wire harness to hook it up to U1000? And I know you have a GLS but where did you end up storing the battery? Thanks in advance.
Thanks a lot for your help.
