2nd Row seats not reclining correctly
First post. Long time stalker.
I have a 2021 build GLE 300d with the 7 seat option.
The 2nd row seats did, but now do not, recline back to the same angle. When reclined (loose use of the term, they don't recline, but in their normal seated position) the bench (2x) seat is not as reclined back as the individual seat. Its not a huge issue as there are car seats in there most of the time, but when they are removed, there is a notiable 2.2cm (1 inch) difference between the angles resulting in an offset at the top of the seats where they meet.
Has anyone had a similar issue and resolved it?
The car is under warranty, but its just a bit of a hassle getting to the dealer, so if anyone has an 'at home remedy', that would be appreciated.
Thanks.
Dan.
Thanks.
Dan.
It appears I will have to take it to the Dealer.
thanks All.
The relevant TSB is at https://static.nhtsa.gov/odi/tsbs/20...87783-9999.pdf (i think, at least it is the issue that i have)
i will take it to the dealer, but good to know it is fixable.
thanks.
I used the seat top buttons, put both seats in the third row access position and then back, and both were able to be returned to the correct position and angle. No idea why, but I'll take it.
