Retrofitting Rear Seat Entertainment
I so want to retrofit the rear entertainment system.
I talked with my Benz dealer and they said it is easy to retrofit and will look 100% original.
They just need to cut the seats (same size as the adapter) and do some harness/wiring stuffs and install the 866 adapters. Then just plug the display.
They have done it on many GLE/GLS before they said.
Anyone here have some knowledge regarding the aforesaid matter? Is there any risks involved? Should I do it?
I will be so thankful for any kind of help!
I just so happen to have a 000-827-20-00 that I bought my mistake and can send for cheap (but not if you're in Dhaka...) - I wanted the one that fits to the built-in slot on my 2020 GLE, part number 000-827-22-00 and accidentally got the other one and was unable to return it. FYI both options stick out of the seat more than I expected.
I’ve heard good things about the factory ones, but only bad things about the retrofit ones.
thank you,
