20" staggered wheels configuration
Firs time posting here, so please bear with me if the post doesn't include all the info. I have 2020 GLE 350 4 Matic with stock 19" wheels. I am looking to upgrade and I really like 21" staggered set up but after reading couple threads here about 21" wheels I think it would be better to go with 20". However, I cannot find specifications for 20" staggered wheels. Based on the info from https://www.wheel-size.com/size/merc...le-class/2020/ there aren't any 20" staggered set ups specs.
20" option
Front: 275/50R20 8.5Jx20 ET55113
Rear: 275/50R20 18.5Jx20 ET42
21: option (staggered)
Front: 275/45ZR21 10Jx21 ET54
Rear: 315/40ZR21 111Jx21 ET49
I was wondering if anyone tried 20" staggered set up and if they could post their specifications for rims and tires.
However, what you really need to find are 20” tires that are the same diameter as your 19”, while also being of equal diameter front and back, otherwise your odometer will be off quite a bit.
I personally wouldn't go with a non-oem staggered set-up on an AWD car especially one under warranty. Maybe get wheels that accentuate the front/rear offset difference better like these (which I ordered) not sure if you can get them in the States. They have a steeper "dish" look than the AMGs. They are non-staggered 20s.
Good luck either way.
The next step are finding wheels that can properly fit the car while being of a width suitable for the chosen tire sizes.
That website has tons of information. I know front size should be 275/50R20 with rim size 9Jx20 ET57 since that is standard 20" square set up.
Big question is what to use for rear. Rear one should be 315/??/R20 with rim size 10Jx20 ET?? (all question marks are unknown to me).
11
20" option
Finding matches front and rear tires and (aftermarket) wheels IS the problem.
Front Tire: 275/50R20
Front Rim: 9Jx20 and get offset close to 55
Rear Tire: 295/45R20
Rear Rim: 10Jx20 with offset some where in the mid 40s
I don't haul anything heavy with this car so I am not worried about the load as much. I am not sure how much of a problem is a deviation in offset though.
Looks like I can do this as long as I am able to find staggered 20inch wheels I like with 20x9 and 20x10 set up.
Off to hunt for wheels. I will post updates as I find something and eventually pictures with the new set of wheels if I get lucky.
*Edit: Adding picture of the clearance from the site
Front: Left side is OEM tire 19x8. Right side new 20x9
Rear: Left side is OEM tire 19x8. Right side new 20x10
You won't know for sure until you're mounted and check suspension travel at all steering angles.
You're probably OK, but check to be sure.
Mandrus Otto 20x9, ET45 on the front and ET25 on the rear. Tires are 275/50/20.
255/45 R20 front on 20 x 8-9.5
285/40 R20 rear on 20 x 9.5-11
That will be closest to you stock 19s and gove you a nice look and stagger.
[/QUOTE]
off set is my biggest problem when searching for the wheels even in 20" size. They rarely have +50 offsets as recommended by Mercedes for rear tires. Looking at your spec you went with 25 in the rear and I am assuming you don't have any problems, right?
Mandrus GLE450
I have to say again, though, especially with the fixed 50/50 awd in the 350, I wouldn't start with staggered profiles and stuff. A guy I worked with started down this homebrew stagger path (I gave him the same warning) on his Porsche and he could never get it to drive right. I don't know if it was the sidewall flex difference or whatever even though all the offsets ODs and stuff were "correct". The traction control and stability control kept coming on at weird times, like hard cornering or bizarrely costing to a stop. Even tried different tire brands, and mixing them up to try to get it to stop. Swap wheels back to original, all fixed. The wheel guys blamed the tire guys and vice-versa. This guy had just sold his NYSE listed company so he had time and money to dick around with it and he sold the car, wheels and tires at a loss to let someone else try. I don't have those same resources, so I won't be experimenting with non-proven staggers. Funny thing, there were guys all over Rennlist claiming it was working for them, so take any advice you get as anecdotal only and might not agree with your car/conditions.
Good luck.
No good ones. Just this ...
