Lane Keep Assist While Changing Lanes (Driving Assist)
If you don't like the responses you receive from those helpful Forum members, read the Owners Manual and interpret it for yourself.
Maybe start a thread and ask how to do that!
Explain to me why the car would jerk me back into my lane with LKA off, my blinker on, with no car in my blind spot or any other object to set off the blind spot alarm. That’s what I’ve said ad nasueum. What in the owner’s manual will address this? Speak up?
To clarify LKA and lane changes, if you engage a turn signal, it will wait until there's an opening in traffic, then make its move when it's safe.
Sometimes I'll want insert myself into a gap more aggressively than the LKA, and it'll fight me.
All systems off in traffic for me.
I do know what you are talking about. With Distronic on, when you try to perform an automatic lane change (Active Lane Change Assist) and try to steer it yourself, it does sometimes try to fight you. But I believe that is from the "Active Steering Assist", not from the Lane Keep Assist (since its the steering wheel that is fighting you, not the brake)
I believe what @mikapen is trying to tell you is that the "lane keep assist" is a different system, and uses brake application when you get close to the edge of the lane vs steering application on "steering assist" which tries to steer the car to keep it in the center lane.
If you prefer steering the car and lane change yourself, you might need to disable the "steering assist". But if you want to just disable the "active lane change assist" and keep the "active steering assist", I don't think its possible.
Edit:
Actually, you might be able to disable "Active Lane Change Assist" while keeping "Active Steering Assist" on.
Although I am not sure if the "Active Steering Assist" will still fight you when Distronic on.
I don’t think it’s the sensors because I’m not getting any proximity beeps like when you do when you turn on the blinkers when a car is there (and like I said, nothing was near me when it happened). I just think the car doesn’t realize the turn signal is on for whatever reason. Maybe sunspots fried its brain.
However, how exactly is that affecting what I’m experiencing? The setting is off and should play no role in any lane change. And, as I’ve previously stated, most lane changes happen without incident.
As for heavy traffic, the lane change assist turns off automatically for me in dense slower traffic. I have to make manual lane changes in those situations. Which is to my point above. It's just an assistance system.
No, I'm not saying you can only change lanes while using auto lane change, but what I'm saying is the above. The steering assist has to know when it's safe to stop auto steering and let you change lanes and not just let go of the steering the moment you turn on the blinker.
However, the incident that happened today occurred during a flat and straight section of freeway with no cars in front or behind me.
I haven’t tried changing lanes without the blinker. I assume the blinker plays no role in steering assist at all then? I need to try that.
Does the blinker turn off LKA with active steering off?
Has anyone confirmed successful lane changes with the no blinker and active steering assist on (and LKA off) to verify the car could care less about the blinker?
Anyways, thanks Superswiss for the explanation. I’m going to try changing lanes with and without the blinker with active steering. I just have to experience this myself.
If the Active Steering Assist is actively steering (a slight turn, or even just a slight adjustment due to uneven road, or it detected the car is drifting to one side, or even on a straight road with crosswind, etc) when you try to switch lane, you might feel the initial resistance from the steering wheel, but the system should disengage itself quickly. This could explain why sometimes you feel the resistance, and sometime you don't. If the car is travelling perfectly in the center and no steering is needed at the time of lane switch, you wouldn't feel anything.
Have you tried just changing lanes without the blinker with active steering assist on and LKA off (on a straight stretch with no active inputs)?
I only tried switching lane with both Steering and Lane Switch Assist ON and I did encounter the the steering wheel resistance when turning once, but then again I usually just drive myself and not use Distronic much so I can't say how frequent/infrequent that happens.
I've learned how the system reacts in different situations, though, so it does make long distance driving rather relaxing if used properly.
If if forces the steering back every time then it does recognize the blinker. And if that is the case, then why the heck does it do it under ideal conditions with the blinker on?
There are some sections of road that often trigger the lane keeper differential braking, even though I’m not not close to the edge. It appears to be caused by a featured in the road, like a gouge mark or tar line. But that does NOT sound like what you are experiencing.
Just to recap, though, the starting conditions: LKA OFF, Auto Lane Change Assist OFF, Distronic ON, Active Steering ON.
1. The car will resist changing lanes without a blinker. It won’t try and jerk me back into my lane, but it also doesn’t want to change.
2. There is no resistance if I turn on the blinker before changing lanes.
3. I did get another strong jerk back while changing lanes with the blinker on again today. No cars near me.
4. I couldn’t get the car to jerk back into my lane without the blinker, although I only made a few lane changes in that condition.
So, the blinker does play a role in active steering; turn it on and there is no resistance to a lane change. Try and change lanes without the blinker and you’ll feel a steering resistance. However, I can’t tell if the blinker/active steering connection has anything to do with what I’m experiencing. What I’m going to do next is turn on LKA and repeat the experiment while continuing to test no blinker lane changes with active steering (and no LKA).
