To rotate or not
Old Dec 7, 2022 | 05:01 PM
Mcfancy14's Avatar
350 GLE 4matic
To rotate or not
So, without crashing too many brain cells, is there any benefit to rotating tires side to side on same axel (the tires on front are larger than rears, therefore cannot do traditional rotation)
Old Dec 7, 2022 | 05:40 PM
chassis's Avatar
2017 GLE350 4MATIC
Yes. Modern traffic management promotes right turns and discourages left turns. Therefore tires receive different wear demands left-right, and tire longevity benefits from left-right rotation. Unless you drive substantially all of your miles on the freeway.
Old Dec 7, 2022 | 08:38 PM
mikapen's Avatar
I agree, plus the crown of the road.
But be aware that some tires are marked Inside and Outside. So those can't be remounted on the opposite side of the same end.
Old Dec 7, 2022 | 10:58 PM
Mcfancy14's Avatar
350 GLE 4matic
Interesting…how exactly are they marked that way, if applicable?
Old Dec 8, 2022 | 12:23 AM
mikapen's Avatar
The word "Outside" is molded on the outside of the tire.
Same with directional Arrows, if they're directional tires.
Old Dec 8, 2022 | 01:56 PM
PandaSPUR's Avatar
Subaru BRZ
Asymmetrical tires (with inside/outside markings) will be fine if you just swap wheels around, the outside will always be facing outside. Its only a concern when the tire is being mounted on the rim.
You're right about directional tires though, swapping from one side to the other will reverse the direction. More info for OP: https://www.lesschwab.com/article/wh...nal-tires.html
Old Dec 8, 2022 | 03:01 PM
HotRodW's Avatar
2021 GLE450
Rotating side-to-side isn't a bad idea as long as the tires don't need to be dismounted from the wheels to do so. I typically don't rotate side-to-side anymore. I simply shift front-to-rear/rear-to-front for square setups once a year when I swap the winters on/off. For a staggered fitment I leave the tire in the same position for the life of the tire.
Old Oct 29, 2023 | 03:25 PM
MBGuy2022's Avatar
2019 S560 4MATIC Sedan
sorry wrong forum
Old Oct 29, 2023 | 06:00 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
I think so, for the four mentioned reasons. Also, when you switch sides, you change the rotation direction of the tire, so wesr is coming from the opposite direction which can help keep tire wear symmetrical.
