Will 2024 GLE 350 U.S model be equipped 48V ECO system battery?
I just wanted to know if 2024 GLE 350 will also be equipped with the same system. If not, I will pull my trigger to buy a 2023 350 now.
Thanks.
"Thanks to mild hybrids with 48-volt technology and the Integrated Starter Generator, as well as the new GLE 450e 4MATIC plug-in hybrid, the entire GLE model range is electrified."
Surprisingly, the 0-60 is only spec'd at 0.1 seconds faster than the current one, but I expect electric motor will be felt across the range, and better start/stop system.
https://media.mbusa.com/releases/rel...ow-even-better
I am guessing in reality, the 2024 GLE 350 with the 48V system will do better than advertised.
However, in 2024 the are also building a GLE plug in hybrid (strong hybrid) - I think will be called the 400e. It will have the same 4 cylinder as on the 350, but will have a large electric motor and battery (much larger than what will be on the 350/450) that can power the car on its own - can be driven as an electric vehicle. It should have an all electric range of 40-50 miles before the useable charge in the battery is depleted and the gas engine cuts on, at which point it will operate like a normal strong hybrid (think Lexus 450h). On a road trip, you just put gas in it and drive until you can recharge the battery. The combined power (engine + electric motor) will be close to the output of the GLE 450 - similar acceleration times, but the gas mileage should be much better. If you drive less than 40 miles/day, you can recharge it at home overnight and you will rarely need gas.
Thats the model I will be interested in.
That said, I see you have the GLE 550e, which I understand has ~15 miles of EV range. When it still has EV range, does the engine stay off during normal acceleration? I understand the 2024 GLE 400e will have somewhere between a 40-50 mile all electric range, so it should be an EV the majority of the time unless you drive more than that a day. I assume if you floor it, the ICE will kick on and you'll hear an I-4, and not an I-6...but it is extremely rare that I've had a need to floor my GLE-350.
