93b vs 94b
Old Jun 24, 2023 | 10:13 AM
manbeing's Avatar
2023 GLE 450
93b vs 94b
Has someone noticed 2024 GLE 350/450 has 94B "integrated starter generator generation 2", while previous year models have 93B "integrated starter generator"
I didn't see any discussion about them here, and i also didn't find any information about the difference using google search.
Is there any improvement in the 2024 model ?
Old Jun 24, 2023 | 10:35 AM
mikapen's Avatar
Where did you see that reference? Press release?
Can you give a link?
Old Jun 24, 2023 | 10:43 AM
manbeing's Avatar
2023 GLE 450
I checked the build sheets.
Old Jun 24, 2023 | 11:28 AM
Frenetic's Avatar
2023 S500
My 2023 S500 has 93B, but the 2023 S580s have the 94B, at least according to this random build sheet.
https://www.mboflehighvalley.com/inv...g7gb3pa197844/
2023 S500:
Old Jun 24, 2023 | 12:06 PM
manbeing's Avatar
2023 GLE 450
2023 S500:
My 2023 450 has 93b, which was built in Mar 2023, the dealer's 2024 450 has 94b which was built in April.
Reliability wise, 93b (gen 1) has been on the market for almost 4 years and is supposed to be stable ?
Old Jun 24, 2023 | 12:11 PM
Frenetic's Avatar
2023 S500
Maybe they started transitioning to a newer model and some 2023s that were built later received the newer part.
I wouldn’t necessarily say 93b is more reliable. Why would they transition to a 94B?
Old Jun 24, 2023 | 01:02 PM
HotRodW's Avatar
2021 GLE450
https://mbworld.org/forums/s-class-w...ation-2-a.html
Old Jun 24, 2023 | 01:11 PM
manbeing's Avatar
2023 GLE 450
This is just comparison with the belt generator.
not for gen 1 vs gen 2
Old Jun 25, 2023 | 06:15 PM
BenjaminKohl's Avatar
2014 Mercedes E350 4matic Wagon, 2018 Fiat 124 Spyder Lusso manual, 2005 Acura TSX manual
Intriguing. The 3.0 liter six cylinder engine, both in 450/43 and 500/53 guise, was the only US user of the "gen 1" 48 volt system (though I believe the last gen 4 cylinder also got it abroad) while the V8 and the newer inline 4 started with the gen 2 system. So it's interesting that facelift GLE450s and 53s now have the gen 2 system as well.
Old Jun 25, 2023 | 11:16 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
It’s already been answered….now part of the transmission instead of part of the engine….
Second-generation ISG and further-developed 9G-TRONIC
The second generation of the integrated starter-generator is being launched in the E-Class models. The electric machine is no longer part of the engine but instead the transmission. This makes it easier to combine the innovative technology with different engines. Accordingly, the 9G-TRONIC automatic transmission has been further developed and will initially be used in the four-cylinder engines. The electric motor, power electronics and transmission cooler have moved to the transmission. As a result, previously necessary cables have been dispensed with, resulting in installation space and weight advantages. The efficiency of the transmission also increases. Example: the improved interaction with the electric auxiliary oil pump reduces the delivery volume of the mechanical pump by 30%. Further contributions to increased efficiency are made by the new generation of fully integrated transmission control with a multicore processor and a new assembly and connection technology. Despite increased computing power, the number of electrical interfaces has been drastically reduced and the weight of the transmission control unit reduced by 30%.
Old Jun 27, 2023 | 01:28 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Does increase efficiency will also produce greater reliability? I have not seen anyone posting problems directly linked to the current generation of the starter-generator. I guess time will tell.
Old Jun 28, 2023 | 08:16 PM
W205C43PFL's Avatar
not at all, thanks for the heads up
Old Jun 28, 2023 | 08:17 PM
W205C43PFL's Avatar
That is good info thank you.
Old Jun 28, 2023 | 08:19 PM
W205C43PFL's Avatar
If it isn't more reliable then efficiency reasons.
Old Jun 28, 2023 | 08:34 PM
mikapen's Avatar
Sounds like efficiency is the driver.
Also, sounds simpler, so hopefully more reliable.
Haven't heard a complaint about any ISG here at all.
Old Jun 28, 2023 | 09:07 PM
W205C43PFL's Avatar
Ya probably will be.
Old Feb 4, 2024 | 05:26 PM
jonpom's Avatar
08 GLK350, 10 E350, 12 R350, 14 CLA250, 18 E400 Coupe, 20 GLE580, 21 GLC43, 21 GLC300, 24 GLE53 SUV
I previously owned a 2020 GLE 580 and experienced same issues. Traded for 21 GLC 43 and had similar issues, though to a lesser extent. Recently traded for 24 GLE53 and it is a dream come true! This 2024GLE53 shifts super smooth and is a pure pleasure to drive. Stop/start no issue at all.
It appears that after several years experience wih ISG, MB engineers finally got it right per gen 2 on 2024 E’s. Hallelujah!!
Old Feb 5, 2024 | 11:38 AM
mikapen's Avatar
My ISG is definitely "right." Imperceptible start/stop, tranny shifts super smooth or super quick, depending on the settings. As it should be. (So was my 2020 450's.)
Plus I don't have the dumbed down MBUX, no 48v problems, and ARC.
I was originally planning on exchanging at 4 yrs, but this may be a 7 year+ car. Lasting into the EV era.🙂
Old Feb 5, 2024 | 04:51 PM
jonpom's Avatar
I’m with you, if it ain’t broke, keep it for 7 years…Besides by that time I’ll be well into my 80s and my kids will probably hide the keys from me! I’m just happy that a car I favor does indeed give me total joy to drive everyday and not frustration, like some of my last 4 or 5 cars.
Old Feb 7, 2024 | 02:59 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
From what I see, the transmission mounted ISG should have the benefit of being able to disconnect from the ICE engine. That alone has obvious benefits. The Gen1 ISG had to spin the ICE crankshaft to provide any input to the transmission. That said the tradeoff is likely a more complicated replacement procedure should it ever be needed.
