2023 GLE Rear Rattle Noise
Old Sep 14, 2023 | 10:32 PM
blastia's Avatar
GLE450
I bought a 2023 GLE 450 months ago and it’s fairly new. There is this annoying rattle sound from the trunk when the car goes on small pothole or uneven road. I think I have pinpointed the spot of where the sound is from. Attached the picture.
The sound come from the interior area around the light.
Wondering if anyone had similar issue and manage to fix. Much appreciated!
Old Sep 15, 2023 | 02:00 AM
wildta's Avatar
GLE 580
Check all of the cargo door hinge and latch attachments to see if any are loose.
Old Sep 15, 2023 | 09:33 AM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Check for anything loose or moving in the spare tire well. Sounds originating from there will reflect off the rear window and sound like they are higher in the car.
Old Sep 15, 2023 | 12:11 PM
wildta's Avatar
GLE 580
Sit in the cargo area while someone else drives around the neighborhood might help you pinpoint it.
Old Sep 15, 2023 | 01:45 PM
mikapen's Avatar
With a stethoscope.
Old Sep 15, 2023 | 10:53 PM
Lanzz's Avatar
2024 E450 AT Wagon, 2024 EQS450+ / Had: 2021 E350, 2019 E300, 2021 + 20 GLE350, 2019 E450 Wagon(s)
Dealer has something called a "chassis ear" which can help you find it. Something to consider in case you don't have any luck finding it yourself.
Old Sep 16, 2023 | 03:08 PM
mikapen's Avatar
I think most if not all dealers have chassis ears. They take a while to set up and calibrate.
They are excellent on suspension and undercarriage noises but not so good on interior rattles.
Old Sep 17, 2023 | 11:29 PM
kook101's Avatar
GLE 450
agree. It’s possible people put that small case with extra tire lug nuts that came with the car in the spare tire area. I almost did that and thought about them rattling.
Old Sep 18, 2023 | 10:43 AM
mikapen's Avatar
Good point.
I put a white glove in my locking bolt box to stop the rattle there.
Old Sep 18, 2023 | 02:17 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Lower the lift gate/hatch, and gently press the rear hatch glass around the hatch frame. Make sure the glass is seated securely in the frame…there should be no sound. If it makes noise have it fixed under warranty.
Old Sep 19, 2023 | 01:55 PM
djgiovanni's Avatar
2021 AMG GLE53 | 2013 SLK350 Sport
I have this same problem and found the problem to be the gas-tank lid. I was able to reproduce the sound by opening and closing the rear right door. I've yet to make an appointment to de dealership, however.
Old Nov 10, 2023 | 10:11 PM
300Zedx's Avatar
Gle350, Audi A6
Same here, gas flap is the problem.
Same issue here, the plastic insert inside the gas flap is defective and ratlles and needs ro be replaced under warranty.
Dealer has to paint gas flap, so it takes a few days to get the car back.
good luck.
QUOTE=djgiovanni;8849240]I have this same problem and found the problem to be the gas-tank lid. I was able to reproduce the sound by opening ansd closing the rear right door. I've yet to make an appointment to de dealership, however.[/QUOTE]
Old Nov 11, 2023 | 12:09 AM
rayzam's Avatar
GLS450 (2026), EQE350+ (2024)
Not a GLE owner, but I've been dealing with a similar issue in my 24 GLS with very similar noise location as the OP. Low rattling noise, only discernable when coasting or driving below 20-30 mph when hitting a small pothole or uneven road (or coming to stop). All windows, interior panels, gas cap/cover, seem to be ok. Emptied out the spare tire compartment to no avail so I thought it must be from under the car/suspension/mechanical. The dealership tested extensively and didn't find anything wrong mechanically and they pinpointed the issue to the spare tire compartment cover being loose (according to them, the noise went away when they removed the cover). They tightened it and put some felt tape at the edges and it helped somewhat but the noise is still there, so they are ordering a new cover and will replace it next week. Will let you know if that fixes it.
Old Nov 11, 2023 | 08:48 AM
chrislk55's Avatar
2023 GLE63S - Edition 55
I had a similar rattle in my 2020 GLE 450. Turned out to be the sun shade for the glass roof. When it's open, it rattled more than when it was closed. The dealer managed to fix it and had no issues afterwards.
Old Aug 2, 2024 | 11:54 AM
PaulCalgary's Avatar
GLE 450
Angry same problem with gle 450 2023
I have the exact problem with my 2023 GLE 450. I just bought it a month ago brand new from the dealership, and I booked an appointment to examine it next week. this noise is driving me crazy when i drive on rough road or a road with slight holes
Old Aug 2, 2024 | 01:08 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Since I originally replied to this post, I traded the 2020 GLE for a 2023 GLE 450 and experienced the same noise. First the dealer replaced the struts on the rear hatch door to no avail. Their next move was to adjust the latch on the rear hatch and that seems to have eliminated about 90% of the noise.
Old Aug 3, 2024 | 06:50 AM
audi40's Avatar
2020 GLE 450
We had a rattle coming from the rear of our 2020 GLE 450 under circumstances as the OP described. My wife initially thought it was coming from the pano roof, but turned out to be a rear strut - fortunately we had an extended warranty which covered the repair. Since OP's car should still be under warranty, have the dealer check it out; as others mentioned, they should be able to pinpoint the issue with chassis ears.
Old Dec 20, 2024 | 03:50 AM
DavePoland's Avatar
I think i found solution
noise is from place where plastic is conecting with steel here :
noise went out and everything is quiet )
greetings from Poland
Dave
Old May 5, 2025 | 05:50 PM
amiansky's Avatar
gle350
Rattle noise
The dealership is recommending that they should replace the rear shock absorber, but I’m not convinced that will resolve the issue. I've also heard that the noise could be coming from the C-pillar/trim area instead. Has anyone been able to fully eliminate this type of noise, or is it a common issue that’s difficult to fix?
Old May 5, 2025 | 05:59 PM
W205C43PFL's Avatar
Better than not trying I guess.
Old May 5, 2025 | 06:00 PM
W205C43PFL's Avatar
Dave
Good job!
Old May 5, 2025 | 09:39 PM
DCJarvis's Avatar
AMG GLE63s (2024)
You can also try this…
https://mbworld.org/forums/gle-class...-easy-fix.html
Old May 5, 2025 | 10:02 PM
W205C43PFL's Avatar
Originally Posted by DCJarvis
Thanks for linking your thread.
Old May 6, 2025 | 10:48 AM
amiansky's Avatar
gle350
Thank you
