Heated and Cooled Cupholders
Can someone tell me what this indicator light means? I know the red and blue below are hot and cold but sometimes when I turn it on this third lamp is red and neither hot or cold is lit.
2019 C300 Cabriolet, 2022 AMG GLE 53
Here is a response from our AI friend chatGPT. Perhaps someone can confirm if this is indeed true or not:
The third light above the heated and cooled button on a Mercedes cup holder usually indicates that the cup holder feature is turned off. This light is often white or another neutral color, showing that neither heating nor cooling is active. This allows users to easily identify when the system is in a neutral state and not actively modifying the temperature of the beverage.
I believe that lights up when you use the heating function, to let you know the area is hot. That's what I assumed. I have only seen it on when I'm using/right after I use the heated function.
Are you sure it comes on when it's cooling? I have only seen it come on when I'm using the heating function and like I said in my post, I always assumed it was a warning indicator to let you know the area was hot.
Here is an excerpt from the Owner's Manual: "If you use the heating function, the metal insert of the cup holder will be heated. Once a certain temperature has been reached, the warning lamp will light up. Do not reach into the cup holder's metal insert when the warning lamp is lit."
The following 3 users liked this post by JRHolt:
False - once again, chatGPT gets it totally wrong. The light on mine is red when I have the heater on, and blue when I have the cooler on. That said, I wouldn't get this option again. It seems that you need a flat bottom cup for the heat/cold to do anything with the cup.
BlueYonder (06-07-2024)
