Break hold not activating
Old Jan 20, 2025 | 04:21 AM
venks0880's Avatar
I have a 2024 Gle 350 and have had it for almost 5 months now. I want to use the break hold feature but even when I depress the break all the way it won’t turn on. I can’t find any related setting to turn it on and when I search online it just says to depress the break 60% of the way. Is break hold a standard feature? I would expect it to be on a basically new $75,000 Mercedes but for the life of me I can’t figure it out. Any advice, thoughts?
Old Jan 20, 2025 | 05:32 AM
xsb00st's Avatar
W167 GLE 53
When I brake, as soon as it stops I lift the brake pedal a little (light enough so the car doesn’t move) then press down on the brake all the way. Hold should come on then.
Old Jan 20, 2025 | 07:07 AM
chassis's Avatar
2017 GLE350 4MATIC
You’re not doing it right.
Stab the brake pedal. HOLD responds to brake fluid pressure rise time (pressure acceleration). Smooth and slow pedal travel all the way to the floor will not engage HOLD. Stab the pedal.
Old Jan 20, 2025 | 08:33 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Or - low accessory battery. Happens in our GLS as it is one mile from home to the clinic...that is what the car does. Does not get driven enough to keep things fully charged.
Old Jan 20, 2025 | 04:34 PM
superswiss's Avatar
2019 C63CS
Yep, standard equipment in every MB. I agree with above poster, you are not doing it right. There is a bit of a learning curve, but once you get the hang of it, it should become second nature. See the linked post below. The video I posted may help.
https://mbworld.org/forums/glc-class...ml#post8592969
Old Jan 21, 2025 | 07:06 AM
TonyF61's Avatar
2022 GLE 450
I believe you have to, first, come to a complete stop, then give it a quick stab.
Old Jan 22, 2025 | 02:38 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
This. Though it will auto engage if it detects the vehicle rolling backward on a hill. I don't remember if the HOLD message will illuminate in that instance though.
Old Jan 22, 2025 | 04:48 PM
superswiss's Avatar
2019 C63CS
That's a different feature and not to be confused with HOLD. What you are describing is the Hill Start Assist and it only temporarily holds the vehicle for about three seconds to give the driver time to move their foot from the brake pedal to the accelerator before the vehicle starts rolling backwards. Therefore HOLD will not light up in the instrument cluster. As opposed to the Hill Start Assist, HOLD holds the vehicle indefinitely.
