Replacing ML320 bluetec tow truck - GLE450 or 450E?
Also getting a 27ft airstream (6600lbs, 7600GVWR). Heavier, but more aerodynamic than we had before. Trying to decide between the GLE450 and the 450e and looking for feedback on realistic gas mileage between those two options, ideally looking for something comparable to the diesel. (14-15mpg while towing, 26mpg+ hwy normally). This will be wife's daily driver as well, so the plug-in hybrid option is a huge bonus. Would definitely need 240+ miles range minimum (and the 450e has a small gas tank). Any feedback from people towing midsize trailers (25-27ft) with either of these would be great!
Or..do we need to look at a GLS450 as well? those are bigger than I'd like (only two of us, so we don't need the extra seats).
Former Bluetec, similar mpg.
For OP, I would recommend looking around on turo (or similar) in your area for a 450e you could rent for a weekend or week, test out pulling your trailer in different conditions (full battery, low battery, etc).
Basically trying to decide between this and the regular GLE450 ..but towing a trailer is a primary use case for us, so was hoping for more than the 10-11mpg I would expect from just the GLE450 while towing?
My main observation was the weight of the hybrid battery pack (under the back seat of the X5) was very noticeable and the towing experience wasn’t great. The X5 had an air suspension and could level the rear end - but the rebound rate of the dampers and air springs made it feel overly weighted down without enough damping to avoid awkwardly large rebound over big heaves / bumps. It just felt very heavy in the rear end and made me less comfortable with the weight distribution over the front wheels.
That said, the low end torque of a hybrid made take offs easy and didn’t present any issues. Modern engines are overkill in most scenarios. I wouldn’t worry about going up hill with a hybrid - I had no issue. I usually worry about going down hill. However, coming down hill the hybrid regen worked to keep the load at speed without activating the service brakes. It was nice.
As for GLE vs GLS - I will say a longer wheelbase is better for larger trailers with big cross sections. Shorter wheelbase tow vehicles can feel like they’re getting pushed around a bit more on the highway by the trailer. Wheelbase is part of the reason crew cab long bed dually pickups feel so much more confident towing fifth wheels (plus the wider rear end) as opposed to a 3/4 ton short bed.
My main advice is this - determine how often you’ll be towing that Airstream and how far you’ll be going. If it’s two or three times a year, get whatever version makes you happy day to day. If you’re going on multi-week adventures for half the year…maybe get the non-hybrid and consider the longer wheelbase of the GLS. Either way, I’d recommend AIRMATIC for towing - both my ML550 and GLE450 had air suspension which I enjoyed while towing. Overall, I’ve been much happier towing with the regular GLE450 over the PHEV X5.
Also, make sure you actually have the tow package and verify your trailer brake pig-tail is in the footwell. I only use a wired brake controller with my GLE - never had an issue.
Edit: the other thing was on long tow days, I felt like I was just lugging around 700lbs of battery for no good reason. And overnight trips didn’t usually give me a chance to fully charge the battery. I did love the EV mode driving around town though. The X5 45e was around 13-17mpg while towing depending on the trailer which was better than my ML550 (9-12mpg), but not life changing. Normal long distance non-towing mileage was between 25-28mpg. Also, smaller tank did mean more frequent fuel stops - and I never got used to having a pressurized fuel tank (push button, wait for car to release the cap).
If I were in the same position, I would lean 450e considering the plug in electric would serve us best 90% of the time.
