Steering wheel controls. Lots of problems
Old Jun 14, 2025 | 06:24 AM
wings02's Avatar
GLE400, 2017 Porsche 911S
We just leased a 2025 GLE 350. This is probably our 6th one. I am having difficulty using the touch controls on the steering wheel, especially the volume. I have the same peoblem on the loaner cars we've been getting also. It seems that the electronic switch doesn't always work if my finger isn't slightly moist.
Does anyone else find this to be the case? f so, are there any tips? Thank you!
Old Jun 14, 2025 | 09:05 AM
Jason L's Avatar
2025 GLE 63 S SUV
Mine work fine with dry hands. I’ve only had my GLE for a few days, but I think I remember seeing a sensitivity setting somewhere. Have you tried adjusting that?
Old Jun 14, 2025 | 09:16 AM
wings02's Avatar
Controls
No but thanks for the tip
Old Jun 14, 2025 | 12:26 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
The. Volume is an issue for me too. Have to swipe it several times. Not like my cabriolet, that still has the actual dial.
Old Jun 14, 2025 | 02:22 PM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
It is much easier to just use the volume control on the center console.
Old Jun 14, 2025 | 07:11 PM
W205C43PFL's Avatar
Thankfully the GLE still has that, on even newer MBs, you are forced to have everything in one screen and also adjust the volume on the steering wheel or more capacitive touch right underneath the screen.
Old Jun 14, 2025 | 07:37 PM
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
They're going back to the thumb wheel for volume on the steering wheel. Here's a video of the new GLC. Hopefully the '26 or '27 GLE will get it too.
Old Jun 14, 2025 | 08:05 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
While it is not definitive, my 24 GLC manual seems to indicate that the volume control on the steering wheel is associated with the volume of a telephone call. I tried using it to control the audio volume with the same difficulty as reported here. Gave up and use the console volume control all the time.
Old Jun 15, 2025 | 09:04 AM
parato's Avatar
2024 GLE 450e
  1. Go to the MBUX Settings Menu:
    • Tap the main display → Settings → System (or Vehicle).
  2. Locate “Touchpad Sensitivity” (or “Touch-Control Sensitivity”):
    • It’s the same feature used for the touchpads in the center console and door panels
  3. Select Your Preferred Level:
    • Options usually range from low, medium, to high.
    • Choose the one that best suits your preference.
Old Jun 15, 2025 | 10:23 AM
If you’re on a phone call, the volume is for the phone call. If you’re not, it’s for audio volume.
Old Jun 15, 2025 | 08:18 PM
W205C43PFL's Avatar
https://youtu.be/gdcH-V-sV24?si=2Q7SeMjiZuBgrLH-
That's a positive change.
Old Jun 16, 2025 | 08:53 AM
mikapen's Avatar
Or the Hey Mercedes lady's voice volume, when she's speaking.
Old Jun 16, 2025 | 09:07 AM
wildta's Avatar
GLE 580
Same with navigation audio, it'll adjust that volume when it's speaking.
Old Jun 16, 2025 | 02:27 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
I absolutely HATE the touch controls on the steering wheel.
Old Jun 16, 2025 | 03:54 PM
Hate is too strong a word. I strongly dislike them.
Old Jun 17, 2025 | 09:17 AM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Nope. I hate them.
Old Jun 17, 2025 | 01:59 PM
mikapen's Avatar
I get along quite well with my 2021 steering wheel controls. It's another reason I decided to keep it when it went out of warranty.
Old Jun 17, 2025 | 07:25 PM
W205C43PFL's Avatar
I would say that is wise, I mean why pay more to change something you like and works for you?
Old Jun 25, 2025 | 04:53 PM
pjw1967's Avatar
Elivisfan0108 is correct. My post above was misleading. Sorry. That said, I messed around with 2 things. The sensitivity setting seems to control how fast or slow the system reacts when you swipe a volume control. On Slow I swiped and there was slight delay for the volume control to work. On Fast it followed my finger right away. But the interesting thing I discovered is what happens with different fingers, I use my index finger to swipe the dash control I use my thumb to swipe the steering wheel control. Index finger fine. Thumb on steering wheel not so much. When I use my index finger on the steering wheel control it behaves the same way as with the dash. Of course that's a bit clumsy and requires a quick glance to see the finger placement. It looks like I use more finger surface when I use my index finger. Next is to see if the controls are reacting to heat or pressure. Hmmmm....
Old Jun 30, 2025 | 07:15 AM
wings02's Avatar
My 25 GLE350 is my 6th MB SUV. I do like the car but the volume control on the steering wheel is the worst. It's the same problem when I get a loaner. When your finger is moist, the volume control works fine. MB should have a no cost option of a little tray to put a wet sponge in. Lol
Old Jun 30, 2025 | 02:37 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
My advice is to use some sort of ceramic cleaner or spray that leaves a very slick surface. Every week when I wash my car I wipe those controls down with a ceramic spray sealant I also use for the paint, and it leaves them very slick and the slider controls work much better.
They are never great though.
Old Jun 30, 2025 | 03:49 PM
mikapen's Avatar
Capacitive controls only seem to work for certain skin types.
I'm glad my '21 has the roller control on the steering wheel, like the one on the console.
Old Jun 30, 2025 | 04:06 PM
Petersla's Avatar
2024 AMG GLE53
I read a piece of advise, somewhere, that by curling your finger and using the tip of your finger, vs. the pad, it works better. I found this to be true.
Old Jun 30, 2025 | 04:24 PM
SW20S's Avatar
2024 S580
At least you still have the roller on the console. The W223 S Class is all capacitive!
Old Jul 1, 2025 | 01:45 PM
parato's Avatar
2024 GLE 450e
your cell phone is all capacitive. It was a pain switching from blackberry keyboard but we all learned… some slower than others
now that I sounded snarky enough , I admit to preferring hard switch’s on the dash for climate control and other common functions
