Left rear turn signal malfunction warning
Old May 8, 2026 | 02:18 PM
Kukumav's Avatar
GLE 350 DE MY 22
Hi everyone, I have a Mercedes-Benz GLE 350 de, 2023 model, V167/W167, and I am having an issue with the left rear turn signal. The car shows a left rear turn signal malfunction warning, and the turn signal symbol on the instrument cluster flashes rapidly, as if one of the bulbs/LEDs is faulty. However, when I check from outside, the left rear indicator appears to work normally. The LEDs light up and blink just like the right side. At first, the warning appeared occasionally, often in the morning, and then disappeared after a while. Now it seems to appear almost every time I drive the car. I have already taken the car to an authorized Mercedes-Benz dealer twice. Both times they only cleared the fault codes, but they did not find or fix the actual cause. The warning came back again after a short time. Has anyone experienced the same issue on a GLE V167/W167? Could this be caused by: - a faulty rear lamp unit even though the LEDs appear to work,- a bad contact or wiring issue,- moisture in the rear light connector,- a trailer/towbar module or trailer socket issue,- incorrect resistance detected by the control unit,- or a software/coding problem? I would appreciate any advice or experience from anyone who has had this problem before. What was the actual solution in your case? Thanks in advance.
Old May 9, 2026 | 08:37 AM
W205C43PFL's Avatar
If the current one doesn't find the issue try another dealership.
Old May 10, 2026 | 11:55 AM
FireRx Captain's Avatar
2020 GLE 350 4Matic, 2016 E350
concur. go to another dealership or an approved MB repair shop. Some dealership are definently better than others.
Old May 10, 2026 | 07:43 PM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
This has been reported in the W213 forum.
Happened to my E63. Occurred randomly, like 1/10 of the time using the car, randomly either left or right rear turn signal. Would work fine after turning off the car for a few minutes and driving again. I replaced the battery and it's been fine ever since. Unclear though if that was true cause.
Old May 11, 2026 | 01:30 PM
Kukumav's Avatar
GLE 350 DE MY 22
I got tired of going back to the dealership and explaining the same issue over and over. So I took it apart myself, removed the light module, checked the sockets, and sprayed some contact cleaner. It’s working now — we’ll see how long it lasts.
Old May 11, 2026 | 04:43 PM
W205C43PFL's Avatar
Good job hopefully that is all it needs.
Old May 11, 2026 | 10:09 PM
taphil's Avatar
Where's the module located?
Old May 12, 2026 | 04:09 PM
Kukumav's Avatar
GLE 350 DE MY 22
i mean tail light itself and cleaned sockets
Old May 12, 2026 | 04:12 PM
Kukumav's Avatar
GLE 350 DE MY 22
it was rainy all the day and didn't get the problem 🙃
Next project is installing the running boards . I hope solving the tail ligt problem didn't pump more self confidence than I need 🙃
Old May 12, 2026 | 04:59 PM
W205C43PFL's Avatar
Awesome, music to my ears and nah don't jinx it.
