Cabin Air Filter Questions!
I also have a bad smell coming from the ac when ever I turn it on!
Thanks!
Good news is, it's all covered under warranty, even the filters, as part of the smell fix. Assuming you're still under factory warranty that is.
https://mbworld.org/forums/new-m-cla...lower-air.html
^^ More info and linked the LI there.
the funny smell appears on my gle when the car stops by the auto stop function. The engine is stopped but mainly everything else is working, obviously something on the AC systems stops and the smell appears. After the auto stop starts the engine, it takes a few seconds to disappear that smell. Amazing Mercedes-Benz!
The bacteria thing is my theory because I once had an air purifier in the house which smelled like sh*#t. I googled it and people said that they do that when there is bacteria in the filter.
as I said, I will contact the dealer and see what solution brings.
I have seen "most" dirty-gym-shoe smells occur when customers turn their air con to ultra-low/max-low and leave it there - which causes frost to build up on evaporator - which is turn causes aircon to be less efficient (meaning you keep on ultra-low because is doesn't feel cold enough) and that frost accumulation melts when car is stopped/turned off - leading to "bacteria/mold" wet environment in the evap box - which will drain water - but doesn't let soaked/melted/frost ultra/damp box dry out to kill that ****..
i sprayed foam into the coils after removing blower motor but it did not help, I guess the liquid did not get to problem areas. Also, drain underneath seems covered with heat shields and other plastics. Any help would be much appreciated.
