2 quick GLE43 questions
2017 GLE43 AMG
Forgive me if either of my questions have already been asked as I'm new to this forum. Wondering if I could get some help with two points. I just picked up my 2017 GLE43 AMG suv, my questions are:
1- anyone know how many lbs of boost these put out just the way it is, 100% stock?
2- I've seen pics where you can display your gauges on your main 8" center screen but can't figure out or find how to do that?
Thanks for the help.
Question 1:
Horsepower 362 hp
@5,500-6,000 rpm
Torque 384 lb-ft
@1,800-4,000 rpm
Question 2:
From the controller:
Vehicle/Dynamic Select/Engine Data
The gauges are Torque, Horsepower, Engine Oil Temperature and Transmission oil temperature (AMG vehicles only).
This is in the COMAND Manual, not the regular Operator's Manual. Use the app below to download vehicle manuals for your smartphone. There's also a PDF version. Both versions allow easy "keyword" searches and bookmarking. That's how I find things quickly.
https://play.google.com/store/apps/d...es.usa.android
https://itunes.apple.com/us/app/merc...945419347?mt=8
https://www.mbusa.com/mercedes/servi...-SUV_AMG GLE43
2017 GLE43 AMG
Thanks for taking the time to answer the questions. I'm gonna check out the command instructions in a bit. As for the first question i know the power and torque numbers the motor puts out. What I'm wondering is how man lbs of boost the turbos make? As in psi.
Thanjs
Thanjs
Unfortunately, I'm still in the "break-in" period, so I haven't been able to put it through its paces. I've been driving gently. They recommend staying in "Comfort" mode for the first 1,000 miles.
You might get your boost question answered from someone like Renntech or another MB tuner that should have stock numbers...haven't seen it posted anywhere as of yet.
GLE43 SUV when trade-in of Sequoia Platinum complete
Boost pressure: looks like maybe 15 psi:
https://www.mbusa.com/vcm/MB/Digital...ases/GLC43.pdf
[I obviously have way too much time on my hands - :-) ]
The AMG 3.0-liter V6 Biturbo engine is characterized by a powerful output together with low consumption and emissions. Installed close to the engine, the two turbochargers are able to provide power without delay. The high power output of 362 hp is attributable to, among other things, a higher boost pressure of 15 psi.
I don't know that I would consider 15PSI a "high" boost pressure. Diesels are like 25PSI...
My modified Evo pushes over twice that on a stock bottom end.
