GLE Class (W166) Produced 2015-2019
heads up display mercedes benz models
Old Feb 16, 2018 | 08:17 PM
Golson16's Avatar
550SL
Which models of mercedes benz have heads up display
Old Feb 16, 2018 | 10:24 PM
Jessey29's Avatar
GLC 300 4matic
Probably most do,my 2018 Glc 300 4matic has HUD, my favourite feature.
Old May 25, 2020 | 08:37 AM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
seems there it's an official OEM kit to retrofit HUD into GLE... anyone do this yet? Im thinking about it... kit is about $1000 to 1200 In parts and requires coding at dealer... install can be DIY
Old Jun 6, 2020 | 10:15 AM
graffixnyc's Avatar
2024 GLE 450 4MATIC
I actually looked into this. I asked my MB service center about installing it if I got the parts. They first wanted to see if it would accept the code needed since it's only offered in Europe(I'm in the US). They wanted me to bring it in to see if it would accept the code before I went and bought the parts. It did (so my GLE already has the code enabled), they then said it would be around $575 for labor to install. I also found a parts store in Europe that sells the parts cheaper than what I saw them for on eBay. It would be around $661.20 for the parts delivered to the US. So around $1236 total for the parts and installation. MB said they dash doesn't have to be cut, it's just mounted on the dash.
https://www.ebay.com/itm/Mercedes-Be...s/183550893849
That listing shows 3 parts: "Manufacturer Part Number: A1669069602 + A16668906009051" and "Other Part Number: A1668200900"
I'm not sure if that 3rd part is really needed or not but it's not expensive so if I do decide to order it, I will get it just to be safe. Also, since MB already activated the code for it, I'm thinking of going to my normal mechanic/body shop to install it as the labor would probably be cheaper than what MB charges.
The site I found all three of those parts is:
https://www.fixparts-online.com
Old Jun 6, 2020 | 03:13 PM
whitewagon's Avatar
let is know how it goes... does MERCEDES have a specific labor rate or code for installing?
seems like a nice upgrade
Old Oct 17, 2020 | 04:22 AM
bigmacnz's Avatar
AMG GLE63S
Have you managed to get this installed?
Old Oct 17, 2020 | 04:32 AM
bigmacnz's Avatar
AMG GLE63S
have you installed this yet and could you pls tell me the code to get mb to check on?
thanks
Old Oct 17, 2020 | 09:01 AM
chassis's Avatar
2017 GLE350 4MATIC
@whitewagon @Patrick Hill HUD for W166? Are you sure?
Old Oct 17, 2020 | 09:37 PM
bigmacnz's Avatar
AMG GLE63S
can you please show a picture of where the hud is mounted?
Old Mar 26, 2021 | 06:51 PM
bigmacnz's Avatar
AMG GLE63S
I have ordered the hud setup.
In the post it mentions 3 part numbers.
You must order all 3 as one is for the projector, the outer assembly and the wiring loom.
This is not a sit on top of your dash setup. The area above the cluster must be cut as the projector sits inside.
I found a video on YouTube that shows the dash being cut.
I’ll be having it fitted in the next few weeks.
Finally you don’t need a special windscreen as there is a small lcd that motorizes up so you can see all the info.
Old May 29, 2021 | 07:21 PM
bigmacnz's Avatar
AMG GLE63S
Well I’ve had the kit installed and it looks great and has great functionality.
I had the trim covered in Napa leather to have it blend into the dash.
Old Jul 26, 2021 | 08:06 PM
gle43FL's Avatar
Veteran: Army
2024 GLE580, 2013 Jeep Wrangler, 2018 GLE43 AMG *Sold*
Sounds interesting. I had a heads up on a BMW and found it very useful. Can you post a picture of the install?
Old Jul 31, 2021 | 08:29 AM
bigmacnz's Avatar
AMG GLE63S
Here you go.
Old Sep 10, 2021 | 05:50 PM
Endless Automotive Admin's Avatar
Former Vendor of MBWorld
I believe not only the trims and hud, but windshield must be also replaced..
Old Sep 10, 2021 | 06:28 PM
bigmacnz's Avatar
AMG GLE63S
The windshield does not need replacing. The hud I have has its own screen so it does not project onto the windshield.
The hump above the cluster has a hole cut into it so that the lower hud mount and hud module sit inside above the cluster unit. The top hud trim then sits on top as seen in my photos.
Old Sep 11, 2021 | 06:41 AM
D49's Avatar
D49
R231 SL
Thanks for sharing this - it is really interesting. Would you be able to show a video of what actually comes up on the pop-up display while in use? It's super hard to find any decent information on it.
Old Sep 11, 2021 | 10:03 AM
SmokinJoe's Avatar
2021 E-350 Loaded
Here is a good short video. Wife wanted to order it, I don't like it much. You can't bring it down low enough without cutting off lower data. I would not have purchased it if not for the wife.
Old Sep 11, 2021 | 03:02 PM
D49's Avatar
D49
R231 SL
https://www.youtube.com/watch?v=-VjJKweHOVc
That’s for the more modern on-windscreen version, not the first generation pop-up style that bigmacnz has, I think?
Old Sep 11, 2021 | 04:00 PM
chassis's Avatar
2017 GLE350 4MATIC
HUD was not a factory/OEM option was it?
