GLE Class (W166) Produced 2015-2019
GLE43 Transmission Filter and Fluid Change Procedure (725.0)
Old Mar 28, 2023 | 04:08 PM
BanjoDude's Avatar
2022 AMG GLE63s
Hi everyone,
I'm getting ready to do a transmission filter and fluid change on my 2017 GLE43. I see varying opinions on draining the torque converter. I also see conflicting reports on how much fluid it should take. I ordered a kit from FCP Euro which includes the filter, fluid (10L) and bolts. I also ordered the special tool kit to drain and refill (I already have a Mityvac Fluid pump). Any words of wisdom from the group before I take on this task? I'm at 100K miles (dealer did the first change), and I hope to go for another 50k or so before I get a new one, so I'd like to take good care of it. Thanks in advance for your help!
Wes
Old Apr 2, 2023 | 10:44 AM
BanjoDude's Avatar
2022 AMG GLE63s
Bump
Old Apr 2, 2023 | 09:01 PM
tkelley.EClass's Avatar
2014 E350 Sport (sold), 2015 S550 Sport (sold), 2018 S560 Sport (sold), 2018 GLE43, 2014 E550
And another bump! Also need to do this soon!
Old Apr 4, 2023 | 05:34 AM
amusa's Avatar
16 GLE400 4matic
You need new pan bolts they cannot be reused. For the 9 speed 725.038 total fill is 10.6 quarts.
Also you need to know if you have code A89 (Reduced-Friction) or not because there are different part numbers not sure if this applys to the 9 speed trans. I would look into it just to be safe when ordering parts different filters and trans fluid..
Some information to look at
https://mbworld.org/forums/gle-class...75k-miles.html
Old Apr 12, 2023 | 12:10 PM
phamq1979's Avatar
W205, W124, W166
I did this on my GLE400. Since yours is a 4matic, you will need to remove the two braces on each side of the transmission then drop the transmission. Use a hydraulic jack to hold the transmission up while you drain and refill.
Old Apr 12, 2023 | 07:25 PM
chassis's Avatar
2017 GLE350 4MATIC
Dropping the transmission is not part of the WIS instructions.
WIS instructions are likely on this site somewhere.
Drain the torque converter if it has a drain plug. Not all torque converters have drain plugs. The only way to know if yours has a drain plug is to visually inspect it.
Watch lots of YouTube videos on this, there are some out there. Senior Leigh on YouTube has good videos on the 722.9 for W212 E350. The 9G will be generally similar.
Excellent video here:
Old Apr 12, 2023 | 07:32 PM
Thanks guys!
Also yes, mine is the 9g so I think it will be a bit easier of a job. Going to check out the video shortly. Luckily, this is preventative maintenance and I have the parts already so no big rush!
Old Apr 12, 2023 | 09:41 PM
phamq1979's Avatar
W205, W124, W166
https://youtu.be/o7Jon2krzv0
So I do have the 9G but due to that its 4Matic, you have to remove the braces on each side and the transmission brace in order to be able to remove the pan. So when removing all three braces, the transmission will drop and that is why you will have to use a hydraulic jack to support it. Its pretty simple. Just time consuming. The video there shows the GLC300 rwd and not 4matic. Setup underneath the GLE with 4matic is a little different.
Old May 1, 2023 | 06:59 AM
amusa's Avatar
16 GLE400 4matic
That's odd There was no braces on the 7G to remove. Do anyone has a photo of the (3) braces on the 9G. I love to see on how the pan is removed.
Old May 1, 2023 | 01:06 PM
sub786sub's Avatar
GLE 350 , GLA 250 and Lexus ES 350
Originally Posted by BanjoDude
Hi everyone,
Wes
I used the return line to flush everything in the transmission housing, torque, cooler, and lines. Simple as you just need to disconnect the return line at the housing which is on the passenger side going into the transmission and wait till you see the clear fluid coming out. Add 2 lit each time, start the engine, and measure the return output volume equal to approx 2 lit ( I used a gallon of clear water empty bottle and marked it by adding water from a small water bottle and then emptied it before using it as a measuring container for the return fluid ).
Old May 4, 2023 | 04:14 AM
amusa's Avatar
16 GLE400 4matic
After watching a 9G trans service on a W222. You do have to remove one support brace because the trans pan sets above it. and the Trans mount brace and that's where you need to support the transmission to drop the pan due to one trans pan bolt. I'm thinking it's almost the same way as in the 9G GLE/GLS.
Old May 6, 2023 | 04:01 PM
chassis's Avatar
2017 GLE350 4MATIC
W166 with 725 transmission, but OM642 diesel.
GLS450 with M276 3.0TT and 725, shows some transmission work.
Old Apr 18, 2024 | 12:41 PM
ukalum's Avatar
GLE43
Any update on the Trans Fluid Change on the GLE43? Was it difficult to remove the trans pan? Was there a torque converter drain plug? How many quarts of fluid.
About to tackle this on my 2017 GLE 43 and need any advice or encouragement you have.
Thanks!
Old Jan 28, 2026 | 10:00 AM
Sammy1836's Avatar
GLE 400
How many litters/quarts did you need in the end? 6 or 10? im getting mixed answers lol
Old Jan 28, 2026 | 12:35 PM
ukalum's Avatar
GLE43
if you only drain the pan, you’ll only get about 4 to 5 quarts. What I did was drained and refilled it and drove it for a little bit then came back and drained it again.
I did not drain the torque converter. If you are replacing the pan, consider the amount of fluid that will be in the filter as well.
The drain/refill process is very easy. I do this about every 30,000 miles and do not change the pan or filter every time.
Old Jan 28, 2026 | 01:37 PM
Sammy1836's Avatar
GLE 400
thanks for the reply! I’ve done this once in the past just wanted to refresh my memory before I take it on again, what I’ve never done is the torque converter and I’m wondering if I should and if yes what’s the process? :/
thanks !
Old Jan 29, 2026 | 08:11 AM
Sammy1836's Avatar
GLE 400
Talking
Bump
Old Feb 4, 2026 | 08:15 AM
Sammy1836's Avatar
GLE 400
Anyone please? thanks!
Old Mar 22, 2026 | 09:16 AM
2018GLE43's Avatar
GLE43 AMG, GLE 400
10L with torque converter. Also, I used the ATF cooler line to pump out exactly 2.5L each times, and pump back in 2.5L -- repeat 4 times without changed the filter and pan. I replaced the fluid every 4 years and replaced the filter/pan every 8 years.
Refer to image for one man job, observe the bolt from blue arrow, and use a big flat screw driver at yellow arrow to move the teeth while looking for the bolt. If you have a helper to move the cam with 17mm socket while you observe the bolt at the blue arrow. The youtube link show you how to
