GLE Class (W166) Produced 2015-2019
GLE43 2019 tire pressure warning
Old Nov 11, 2023 | 12:02 PM
Scott Minor's Avatar
2019 GLE43 SUV
Why is the car complaining. This summer is happy at 40psi warm tire pressure.
Old Nov 11, 2023 | 01:50 PM
W205C43PFL's Avatar
Just reset the TPMS and carry on, should solve the issue.
Old Nov 11, 2023 | 03:01 PM
2019 GLE43 SUV
I never ran such high tire pressure in my 2018 GLE350 with the 20”AMG wheel option. I think I need to drop the fronts to 41.
Old Nov 11, 2023 | 03:12 PM
W205C43PFL's Avatar
Yes, your second image is too high, make sure to measure the tire pressure when tires are cold though (cold tire pressure), you did the right thing to use the tire pressures on the fuel door and not where the door sill is.
Old Nov 11, 2023 | 03:21 PM
2019 GLE43 SUV
I’ll have to wait till I get home and get let them “chill out” a little 😁
Old Nov 11, 2023 | 03:50 PM
2019 GLE43 SUV
I think cold at 39 and 41. I think that’s what the gar door temps are recommended to be. Hot temps would be 42 and 44.
Old Nov 11, 2023 | 03:51 PM
W205C43PFL's Avatar
It is no rush to be honest, you could still just drop off a few PSI even when it is warm then drive home and then check it next morning before you take it for a drive. Factor in the temperature differences between the garage and outside though, remember, tire pressure changes like 1 psi every 10 degrees Fahrenheit change. You want to also check manually with a gauge yourself as well though.
Old Nov 11, 2023 | 03:52 PM
W205C43PFL's Avatar
Hmmm ignore my other reply the part where I talked about temperature fluctuations, turns out you already know what you are doing so that's good.
Old Nov 12, 2023 | 04:31 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
As mentioned, you can reset it on the cluster, but reading the door label,
for loaded car you need 45-49 psi , so 39 alarm sounds about right.
Obviously when you drive empty all the time, you will use different line
