GLE Class (W166) Produced 2015-2019
Weird issue with cruise control
Old Feb 1, 2024 | 03:28 AM
PitrRepeater's Avatar
GLE coupe 400 petrol, C292, 2016
Hello folks ! Guys, please tell me. I have weird issue with cruise control (classic speedtronic, not adaptive) on GLE 400 coupe 2016. I bought car with an error: cruise control and speedtronic inoperative. After buy I visited MB workshop, they reflashed software from cruise control and it worked great. Now its about 14 days - when I pull cruise control lever - time to time it says speedtronic inoperative. Sometimes also before cruise control shuts off - I see on display: cruise control: - - km/h. And then error message. After stop and letting car off for some time. Issue is gone and its working again. I have fooking no idea what it can be ? I have new main battery. Otherwise no idea. no other errors. Update: since today, cruise control doesnt work at all. Even I let car over night off, it doesnt work anymore
it could be AUX battery ? (around 8 years old, no error message. Main battery is brand new.
abs / esp works fine, no problems.
speedo works, but it could be speed sensor issue ?
no other issues everything works. Just that good damn cruise control is annoying
Old Feb 2, 2024 | 04:20 AM
amusa's Avatar
16 GLE400 4matic
8 years on the original Aux battery? it's time to replace. Usually they last up to 6 or 7 years.
I would get the code pulled from a good scanner.
Old Feb 2, 2024 | 10:45 AM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
Since you had the vehicle refreshed at the dealer, usually they offer a warranty on their repairs...
Reach out to them and say the reflash didn't work and ask them to rediagnosis... they should do this free of charge.
Old Feb 5, 2024 | 10:28 AM
So today connected car to a diag and run test (not Star diag). Issue regarding cruise control is: P0579. Any idea what this can be ?
Old Feb 7, 2024 | 04:14 AM
amusa's Avatar
16 GLE400 4matic
Cruise Control Multi-Function Input "A" Circuit/Range Performance. PCM (Powertrain control Module).
I would check the Cruise Control Master Switch, Clock Spring and wiring issue. My guess is the Cruise Control Master Switch. I would start there first.
Old Feb 7, 2024 | 06:12 AM
so do you think, that cruise control lever is defective ?
Old Feb 8, 2024 | 10:13 AM
amusa's Avatar
16 GLE400 4matic
Like I said replace the Aux battery first then clear the code and if that code comes back then start looking at other areas like I mention "Cruise control master switch, clock spring, etc.)
Old Feb 11, 2024 | 01:24 PM
so buddy, fixed ! Ive noticed that lever from cruise control is not moving as it should. Turned car off and moved manytimes up and down, now it works perfectly.
