2017 GLE 350 Aftermarket wheels and lug nuts
My issue is all the 20 lug nuts are keyed lug nuts that use 10 spine key.
I hit a curb and had a flat, surprisingly the previous owner didn't leave the key in the car, lucking I was able to put air in it and got to a tire shop that had the
10 spine key. I've bought 2 online and they've both had split.
The OEM nuts will not fit, because the wheels takes a cone shape nuts.
I will prefer to a nut with no key, one with a 17mm or 19mm Hex.
Can you please recommend one?
I called DRAG and they said they don't supply accessory to the wheels smh.
The key with aftermarket wheels with Mercedes is finding the correct shank length with the offset of the wheels and if your using spaces or not you need to calculate this as well. I used Ball seat on my CLK you need to find out what type of seats it uses.
mine use the Conical Seat.
i found what I'm looking for...
