GLE Class (W166) Produced 2015-2019
Obd Scanner Search
Old Oct 15, 2024 | 07:56 PM
Sprutz12's Avatar
19 Gle 43
Obd Scanner Search
Hi does anyone know or recommend an obd scanner aside from the factory xentry unit that is able to preform the valve bleeding that is described in the workshop manual when performing a transmission fluid and filter change? Any help would be great. Our vehicle is a 2019 GLE 43/w166.
Old Oct 16, 2024 | 05:14 AM
ygmn's Avatar
2015 E400 Sedan
maybe the Launch Creader - never looked and it does all sorts of things.
Old Oct 16, 2024 | 07:43 AM
W205C43PFL's Avatar
See if this helps https://mbworld.org/forums/c450-c43-...e-success.html
Old Oct 16, 2024 | 09:54 AM
JettaRed's Avatar
Veteran: Army
I am not sure the LAUNCH Creader can do valve bleeding. As a matter of fact, I cannot find "valve bleeding" as a procedure in XENTRY or procedures in the WIS when refilling the transmission. Do you have a document number for the procedures in the WIS?
Old Oct 16, 2024 | 01:58 PM
W205C43PFL's Avatar
That is a good question, will wait till OP responds.
Old Oct 17, 2024 | 11:31 PM
Sprutz12's Avatar
19 Gle 43
I’m not sure if the is a valve bleeding actuation alone in the xentry. It is part of the system adaptation process when performing a transmission service. I believe the process holds the rpm at certain levels while actuation the valves (bleeding) in the transmission. I’ll post an example video if that helps.
Old Oct 18, 2024 | 04:54 AM
ygmn's Avatar
2015 E400 Sedan
what is a ATOMATIC transmission?
see title of video above.
Old Oct 18, 2024 | 09:41 AM
JettaRed's Avatar
Veteran: Army
I think the "valve bleeding" may only be with the 9G tranny. Below are variables that can be set when using the XENTRY Simulation. This was for the 9G transmission.
Old Oct 18, 2024 | 09:46 AM
JettaRed's Avatar
Veteran: Army
According to Google Translate, it is an atomic transmission.
Old Oct 18, 2024 | 10:19 AM
W205C43PFL's Avatar
Does it mean it shifts like an atomic? Either it jerks so violently or it bangs so violently
Old Oct 18, 2024 | 11:07 AM
JettaRed's Avatar
Veteran: Army
I think is it more bad editing...
Old Oct 18, 2024 | 12:02 PM
W205C43PFL's Avatar
I know : ) I played along since you posted that image.
I hope we all had a great laugh, life is about living the moment : )
