Engine seized?
I have a 2017 AMG GLE43 coup with about 80k miles on it. I came home from work last week and parked the car in the garage with no issues. I went out of town for 5 days and while I was away we had a cold front in Chicago and the weather got down to around -15. When I got home I tried to start the car and it would not start. I had power but the stater would make a click sound but nothing would happen. I figured the battery must be low and tried to jump the car, but no luck.
I used Mercedes roadside assistance to tow the car to dealership and now they are telling me that the long block in my engine is stuck and the engine is essentially sized. They are quoting AT LEAST $20k to fix it. They mentioned multiple times that the cost could go higher if they find more issues.
I was wondering if anyone has ever heard of such an issue. To my (limited) knowledge, engines lock up when they’re running, but the car was not running and was sitting in a garage for like 5 days. Also, any suggestions of what to do? I am currently leaning toward just salvaging the car since I don’t think paying $20k for a car that’s worth $30 is exactly a good financial decision; however, salvaging it will cost me around $25k since with the engine sized the car is valued at like $5k.
any thoughts or suggestions are highly appreciated.
Was car outside or in garage?
If inside heated or open windows?
Was it cold enough for whatever you had for coolant freeze and crack block?
IE any fluids in oil or on ground?
Other wise ask them how this could happen?
You drove it home and parked it and all was fine?
Then you left it alone for some very cold days.
now it does not start.
there are no leaks or anything on the floor. I asked the dealer and they didn’t see any coolant leak either.
yup! I drove it home, parked it the garage, and 5 days later it wouldn’t start. I thought it was the battery or the starter, but the dealership looked at them and said they’re all good. They took a closer look and said the long block is stuck. They said they don’t know the cause and it would cost more money to do more diagnostic to figure it out.
If you ever have to go that route, still hoping your dealership is wrong with the diagnosis.
If the car ran and gave NO signs of a problem before, you probably don't have a mb problem, you have a trustworthy dealership problem. As was suggested, you can remove plugs and manually crank engine to get it unstuck IF that's the problem. If you're in Chicago I KNOW there are great mechanics there. I haven't been to the guy but while there visiting my family I spoke to several mechanics who told me to go to the shop on the corner of Harlem and 111th st. I don't remember the name but at least look him up and call. Maybe he just does tires and brakes, I don't know but when everyone recommends someone, give that person a call and if they can't do the work they will likely recommend someone THEY trust.
Another thing is its possible that the jump start you got wasn't enough. Clicking usually means there's not enough electricity to engage the starter. Doesn't mean engine is broke. So a battery should be over 13 volts and have enough cold cranking amps CCA to start the car. Just because a battery fits doesn't mean its right for the car.
last option that I saw here is get a used engine from a wrecked vehicle and have an independent mechanic install it. Make SURE they know something about mb. Keep in mind that you have a AMG so a high mileage engine is ok. Mine has 185k miles and its still a beast. Our engines can do a million miles if taken care of properly. So find a used 1 OR get yours rebuilt by a good shop and don't scrap your beauty. Its worth saving.
I hope this book i just wrote helps 🤣
