C292 2017 AMG43 GLE coupe turn signal color issues
Old Aug 23, 2022 | 05:29 AM
Charlie_Moore's Avatar
2016 W205; 2017 C292
Had a local technician remove the front left LED headlamp unit to repair a cracked point on the glass and upon test after re-installation, the turn signal color changed to violet.
can anybody advise on the way to solve this color issue?
Last edited by Charlie_Moore; Aug 23, 2022 at 05:35 AM. Reason: More specific model
Old Aug 23, 2022 | 07:59 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W166 AMG forum...
Old Aug 24, 2022 | 08:54 AM
Frenetic's Avatar
2023 S500
That’s kind of interesting. How did they repair it? I thought the entire housing was one sealed unit?
Old Aug 25, 2022 | 03:05 AM
I actually got a full headlamp unit from ebay that had some sockets that didn’t match mine, so I was advised to surgically cannibalize the glass from the ebay unit to mine, as other than the cracked glass, it was working just fine. They did that & it was quite a good job.
so it turned out the same headlamp unit but with the entire glass changed
Old Aug 25, 2022 | 08:07 AM
Frenetic's Avatar
2023 S500
I don’t know if the glass or acrylic could affect the color of the led beneath? It’s not unheard of, but seeing it would definitely provide some credence either way. Or, by simply unplugging the unit, maybe some coding defaulted back to a factory or default state, which changed the color.
It might be helpful to make a short video of the blinker and post it.
Old Aug 26, 2022 | 06:21 PM
See a video of it now.
File Type: mov
Old Aug 26, 2022 | 06:40 PM
Frenetic's Avatar
2023 S500
That’s interesting. Is the daytime running light still good? I assume the turn signal and DRL are the same?
It definitely doesn’t seem to be the headlight cover causing the discoloration and more LED related itself. I really don’t know what to say. Maybe by unplugging it the light or coding defaulted to a preset color. It’s either that or the bulb is going bad. Too bad MB restricts coding. If this were any other German brand it would have been easy to see there was a factory default setting for that light strip.
Old Aug 27, 2022 | 07:34 AM
File Type: mov
Old Aug 27, 2022 | 07:52 AM
The DRL works just fine being white. SCN coding was suspected too by the technician initially but if that doesn't have to be the case, another Benz user saw it as being dope and recommended to unplug the right headlamp unit too, to make both display violet upon signalling.
I took this suggestion with a shrug. See a video of the DRL
Old Aug 27, 2022 | 10:25 AM
Frenetic's Avatar
2023 S500
Yeah, simply unplugging the other light might be the easiest fix. Even if you don’t, I don’t think anyone would notice unless you have the hazards on.
