w166 GLE63S m157 Spark plug replacement Stage 2
Old Mar 30, 2023 | 10:47 AM
B5beauyo's Avatar
2011 Porsche Turbo S
Is it recommended to step to a colder plug when going to stage 2? I have a fuel cut issue that comes around at high load partial throttle times. Looking to swap plugs first. Stock ok or should I go with the NGK one step colder option?
Old Mar 30, 2023 | 05:51 PM
SL55designo's Avatar
SL55
I have it as well. I went one step
colder gapped at .022 and the issue still persists. Can’t get it to go away, I feel it’s in the ECU and when higher booost is detected under load it cuts the fuel for a split second almost as if it’s spark blowout. I am convinced, after going one step colder and playing with the gaps it is not spark blowout but rather the ECU cutting off fuel under higher boost. I can’t stand it. Do me a favor try Manual mode in 5th gear and see if it does it around 2500-2800 rpm’s. Report back and let me know. I have the fuel cutout really bad here. Who’s tune do you have?
Old Mar 30, 2023 | 05:54 PM
B5beauyo's Avatar
pmd you
Old Apr 2, 2023 | 10:05 PM
Lawineer's Avatar
18 GLE 63
I have the same issue with fuel cut. It's random though. Just got new plugs, but it's been raining and I haven't had a chance to go WOT.
Old Apr 5, 2023 | 01:59 PM
B5beauyo's Avatar
Let me know how it goes.
Old Apr 5, 2023 | 02:32 PM
Lawineer's Avatar
18 GLE 63
Driving in traffic today, probably 25-35% throttle and it cut abruptly for no reason. Very weird. I gets my heart pumping every time it happens because it feels like the car just shut off or something.
So I did a few WOT runs to 115ish. No problem.
Old Apr 5, 2023 | 02:38 PM
B5beauyo's Avatar
Never an issue with mine at WOT either.
Old Apr 5, 2023 | 06:10 PM
SL55
This exact issue happens to me on a daily basis. We alll need to try to get it figured out. It’s so annoying and takes away the fun of the vehicle. Although, I will say WOT I am
fine to exactly 115 which is 5th gear and then it cuts fuel there as well for me. I have tried six different pulls WOT to 115 on different days and it happens every time. Try manual mode in 5th gear and see if it happens there. Mine cuts fuel always around 2500 to 3000 rpm’s. I tried plugs, regappimg and even a new tune file and to no avail.
Old Apr 5, 2023 | 08:41 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Who did your tune?
Old Apr 17, 2023 | 02:17 PM
Lawineer's Avatar
18 GLE 63
Originally Posted by BlownV8
Who did your tune?
Eurocharged.
No idea what the issue is, but it's kind of random. It's also pretty rare.
I'm going to run a blend to get to 96 octane and see what happens. Small sample size, but I added a little bit of 110 when I was at the track (driving another car, not this one) and no issues with that tank. Then again, it only happens once ever 3-4 tanks so who knows.
Old May 2, 2023 | 11:04 AM
Lawineer's Avatar
18 GLE 63
So I've got about 1000 miles on it and all seems to be well with the new plugs.
Old May 16, 2023 | 10:04 AM
B5beauyo's Avatar
Did you gap them differently or leave them? Just stock plugs? This is encouraging news! I am swapping plugs Thursday hopefully.
Old May 16, 2023 | 10:44 AM
Lawineer's Avatar
18 GLE 63
Stock plugs. Make sure they are torqued correctly so they point the right direction
Old May 16, 2023 | 10:46 AM
B5beauyo's Avatar
you go with 23nm?
Old May 16, 2023 | 10:49 AM
Lawineer's Avatar
18 GLE 63
you go with 23nm?
I had a shop do it. I had some other service that needed to be done at the same time.
Old May 16, 2023 | 12:13 PM
PeterUbers's Avatar
Are you guys with this issue logging your runs? Are you pulling any codes?
you'll get extra traction on the w212 amg forum
Old May 16, 2023 | 12:16 PM
B5beauyo's Avatar
I haven't gotten any codes from it on my normal scan tool. I am new to merc, so I would love to see how everyone is logging these cars. Coming from 4.0t audi world it is just so much easier to find info on.
Old May 22, 2023 | 11:08 AM
B5beauyo's Avatar
Replaced my plugs Thursday. So far so good!
Old May 23, 2023 | 04:45 PM
Lawineer's Avatar
18 GLE 63
I had misfire and overboost.
Old May 23, 2023 | 04:52 PM
PeterUbers's Avatar
hp tuner
Old Jun 4, 2023 | 04:40 PM
GMBALL's Avatar
S63 COUPE M157
Hi guys,
was it like this? That is during WOT. I always tried to figure why this happened.
https://youtube.com/shorts/kwSFMuz_H_4?feature=share
Old Jun 4, 2023 | 05:18 PM
Lawineer's Avatar
18 GLE 63
Originally Posted by GMBALL
Hi guys,
exactly.
Old Jun 5, 2023 | 03:40 AM
GMBALL's Avatar
S63 COUPE M157
exactly.
So to me it happens only ocasionally (maybe every 3rd or 4th run), mostly 4th or 5th gear and in 95% only during WOT. Speed 115-130MPH. I have changed plugs to Weistec one-step colder, dissapeared for some time, but then reappeared again. I have renntech stage 2 ecu tune/weistec tcu/downpipes/turbo-backs/3"exhaust/sport cats/blackboost cai. It started doing it about 2 years after the stage 2 tune, but it began right after I have installed turbo-backs - my guess is that it added quite a bit to already high power levels and basically it now here and there falls into overboost territory. I have no idea what to do with this issue.
Old Jun 5, 2023 | 06:00 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Please clarify. Following along in the e63 thread.
Did it happen right after the turbo back or right after a plug change to weistec?
Old Jun 16, 2023 | 03:58 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Hey which NGK is the correct one-step colder plug?
I was just changing out my plugs for the first time 2019 GLE63S Coupe, and have a set of NGK 97506 (SILZKBR8D8S) here ready to go in. All of my research says that these are the correct 1 step colder NGK plugs for the M157. However, these plugs seem to be 2-3mm longer than the OE Bosch plugs that I just pulled out (Z6SII3320R). Totally confused. I called FCP Euro and they said that they don’t fit even though they are listed on their website as fitting. NGK spark plug finder says no fitment whatsoever.
When I look up and compare both plug specs, reach is exactly the same at 26.5mm. This is driving me crazy. Can someone help me to settle this once and for all please?
Edit: Went down to my local dealer and got the OEM plugs. Wasn’t worth figuring this out today but still curious. Doing the passenger side plugs on these things suuucks.
