Rock through cooler!
https://m.aliexpress.us/item/2255800920500600.html
the best I could find to solve the problem with this grill and road rocks entering. I am not taking it to a concours event, so I don't really care that
it is only a little noticeable, but then you need to stare to really see the zip ties unless you are within a couple feet of it.
All set for more road trips now....
Screen install (shot taken mid-install, not quite done yet but wanted to get a snap of the grill backside before bumper was put back on):
Front view:
Close-up:
Hope you guys never get stranded by a wayward object puncturing the cooling system.... this fits with my "no drama" rule in life. ;-)
Front view:
Close-up:
Why did you selected the protection screen for the GLE 350’s regular grille versus the GLE 350’s AMG grille?
where a rock could do damage, other than the bottom inside corners. May not be perfect but it should stop 99% of the rocks. I watched my temperature gauge while driving and it seems to have no effect at all on cooling (when driving normally of course).
AggAuto Universal 40"x13" Car Grill Mesh - 100x33cm Aluminum Alloy Automotive Grille Insert Bumper 3x6mm Rhombic Hole, One of the Most Multifunctional Shape Grids Black
The black matches well with the grill and the material is quite stiff so it kind of molds to the contour and does not move. I was going to use zip ties but could not figure how to loop them around the grill laterals and back through the screen. So I used aluminum wire and twisted it to tighten. I then painted the silver wire black to not show as much. Again, will not win a concours but I feel much better with some protection. I am still amazed that Mercedes doesn't protect the radiators better....everyone else seems to be able to do it. They could keep the same grill and just put mesh behind it. Anyway, so far so good.
(Scroll to grill trim)
https://larte-design(dot)com/tuning-kits/mercedes-benz/gle-63/v167-2019-2023/
This forum is masking the link for some reason. Replace (dot) with a period.
My only concern would be that it restricts airflow.
But I'd think there'd be internal sensors that would compensate for that, unless you were driving really hard.
