GLE63S Square Wheel Setup
I wouldn't use the front wheel on the back or vice versa, so you would still need to mount / dismount tires to rotate them.
If you want to rotate tires , you cannot put the rear wheels on the front, period.
You can swap side to side, IF your tires are nondirectional.
I think your idea of a winter and a summer set is a good one. As long as you are aware of the offset requirements.
What HRE wheel model(s) have you been looking at?
I would want to ensure that I have a quality, lightweight spacer. And maybe slightly lubricated, perhaps with anti-seize, depending on dissimilar metals.
I am looking at the P103 most likely or similar design with Vossen
