I didn't know GLK can....
#51
M-B GLE, Porsche 911 Turbo, Porsche Boxster (spouse)
#52
GLA250 4Matic, 911 Carrera S, R1250 GS Adv.
My GLK does not have the power tailgate option and came with the 2-button key. But, having a 3-button key would be desireable even for the non-power tailgate. Does anyone have the 3-button key together with the non-power tailgate?
#53
2006 R500 Obs black. Keyless, comfort, trim, lighting, AMG sport, premium and rr seat ent. packages
[quote=NYCGLK;3592686]ehh I don't know who pays attention to front blinkers, I think rear ones and side ones are usually the key ones.
quote]
As a motorcyclist also, I pay a LOT of attention to front blinkers to know the intentions of drivers coming at me.
quote]
#54
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
#56
GLK 4matic
Where is the vent button
NYCGLK: where is the vent button
#58
GLK 4matic
Thx Baby G, That works only if you are very close to the drivers side of the vehicle. Know any other way that vent can be activated...like say from the inside...Also is there a way to close all windows and sunroof from inside without individually closing them?
Thx.
Bp
Thx.
Bp
#59
GLK 350 4matic
When a/c fan is on Max and you push the voice command bottom on steering wheel. the fan will automatically reduce a notch to lower the noise when you are talking. Now that's true engineering.
#61
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Best voice controls:
media interface (iPod)
memory card (PCMCIA)
music register (6G hard drive)
They bring me to the correct source saving me the clicks on the audio screen.
#62
If your windows fog up, just set climate control to the desired temp level and air will get drier without raising the temperature.
#63
Found this from Tate (https://mbworld.org/forums/3572278-post10.html)
You can tilt down mirror in R for Canadian model (I guess in all trims). Here is how:
- Set gear to R
- Enable the right side mirror button
- Set the mirror to the position you want
- Set gear to P or D
- Mirror will go back to normal position in a few sec
Now you have saved the mirror position in R. Shift gear to R again and it will tilt down and you will see the right side mirror button enabled.
My GLK is Oct 09 production and it works. The only thing I need to do differently is press the Right mirror button while in R (once everything is setup) and then it will tilt the mirror. If I don't have the right mirror button pressed, it won't.
- Set gear to R
#64
you can have this setting changed to a very high number, say 100mph, at the SSSS. so that you can watch your movie when you are below 100mph. (not recommended)
#65
2010 Mercedes GLK 350
Is that information retrievable by us, or just by the dealer?
My wife's BMW has that information right on the dashboard so we can track fuel mileage as we drive. Is that also the case on the GLK?
#66
Just scroll through trip info on MFD. It shows trip info since start of the current trip, trip info since reset, and also has another mile counter, also there is mpg bar indicator and speedo showing in digits. I'd play around other menus there are a lot of interesting things.
